stivep
For these skilled in art:
You know what I'm talking about
Для специалистов  квалифицированных в искусстве Вы знаете, что я говорю ...............
Уэсли
Wesley
Thaelin
  And just did a search for FeZrMg alloy and the search engine went off line. Ok for other things tho. Hmmmmm?
Starting to see a pattern here. But then, if the combo goes beta, wouldn't want to be messing with it anyhow. Now without some lead sheilds.
stivep
As far as I'm aware :)  Tariel in Green box used two grounds  apart from each other.
1- cold water  pipe.
2 copper radiator  soaked with water  and buried at depth of ~1.75 m
the distance between two grounds  was around 25m
and now compare it to Wesley's contribution
Насколько я знаю, Тариэль в зеленой коробке использовал два гранда
  1 - труба холодной воды.
2 медь: радиатор пропитанный водой и похоронили на глубине ~1.75 м, расстояние между двумя грандами былo около 25 м
и теперь сравните его с Уэсли и вклад
Note: please note that distance between grounds  is pointed here - not distance  between  components of Tariel device.
Нота: прошу обратить внимание, что здесь указано расстояние между грандами, а не расстояние между компонентами устройства Tariel.
Wesley
Hoppy
At 11:23 in part 1 it can be seen that the water pipe is the only ground, as the end of the radiator cable can be seen laying on the ground. Despite this Kapanadze has claimed that the devices self-run with just one ground connection. The Aqua 2 device clearly demonstrates this.
Take a look at this shot: -
stivep
Quote from: Hoppy on June 02, 2018, 04:53:11 PM
At first video show  (prior to  link at 10:04)  car radiator    being buried. https://youtu.be/Goq76CQapyI?t=257
please look here .
https://youtu.be/Goq76CQapyI?t=604     link at 10:04
then video shows  water pipe  connection  at 10:58 instead of radiator connection
https://youtu.be/Goq76CQapyI?t=658
Wesley
