stivep
Top Capacitor of Tx
1. It is the structure that is   adjusted in elevation / extended  in height
(the measurement from base to top).
2. It has shape  of preferred   head of  the mushroom..
It can be  however  done from  aluminum "air tube"
Flexible Aluminium Air Ducting Ventilation Accessory
also called : Hose Application: Duct / Exhaust
picture 1
3.It's capacitance can be increased  by internal mechanism of
tube inside of  another tube  with  air  or  Teflon dielectric.
However  other means are allowed by  sliding  piece  of  inner tubing/s
the  effect of such is capacitance match  to desired F of resonance. (picture 1b)
4. Viziv used  on  the  top of  the doughnut additional half semi spherical  structure  .
To increase capacitance  nad manipulate with capacitive reactance of Top Capacitor
Wesley
stivep
Position of  Top Capacitor:
Since Viziv tower is fixed there is no way  to change  potion of Top capacitor in Vertical elevation.
We  may assume that there is whole  mechanism   inside of the  space of
Top  Capacitor to change capacitance of  the  Top Capacitor.
The  Umbrella /(Ambrela) inside of  space  above the  torus.
Wesley
stivep
Next subject to  discuss is :
cylindrical waves
1.- point source
2.  line source
3.  wave front
4.  cylindrical wave behavior in Near Field
This is crucial information to  understand   How Surface wave  is  created in the interface Earth/Air
I will finish  this article later.
stivep
Cylindrical Wave :
Electric field  is perpendicular  to the direction of propagation  and is  gradually  decreasing   with  the distance from Tesla  tower.
Line source    must be  cylindrical  - so is Tesla coil
Magnetic field is   at 90 degrees  to electric field  and fits into  the Earth/ air  area called   -  interface.
This   is our  TM  mode.
Note:
picture 3 is showing Cylindrical Wave
in  medium - Air.
There are two views  the  top one  is at slight tilt.
The  lower on e  is  at YZ coordinates.
Wesley
stivep
Quote from: groot on June 30, 2019, 04:18:20 PM
https://youtu.be/KLAPRNWuAn4  dielectric excitation .
Wesley :
the  bottom  line is  that Pastukhov method
- misinterprets the phenomena
Viziv is using phase shift (time delay) to compensate for wave tilt so they can get physical wave at precise angle (brewster angle LoL).
polarization  of the single TEM wave to  see it   in TM  mode and   in interface.
- Top Capacitor  of that ( single) HV winding of Tesla coil produces Standing Wave
- Vertical elevation  of  that Top  Capacitor is making the  trick
to receive  that surface  wave is need  another Tesla coil  54 foot in the distance or more  from
the  first one.
that  Tesla  Coil can( but doesn't have to)  look like  Tx ( the transmitting  Tesla   Coil)
And (for    the  moment)  nothing more.
I have never came across anything about surface wave, em wave polarization , time delay of a wave
while reading about Tesla or his work.
Jonathan Zenneck  made it known in 1901.
Sommerfeld added to it.
https://en.wikipedia.org/wiki/Jonathan_Zenneck
http://www.tfcbooks.com/teslafaq/q&a_039.htm
Tesla would find it .  but he was  cut short with money .
-Marconi in Bolinas Ca in 1921/4 was restricted by ( government decision with use of RCA )
They all claim he used EM wave ( Radio wave ) for transfer of energy, but all his patents state otherwise .
Then you can read in his colorado springs notes that he used non radiating wave .
Can you give me   link to  the  exact quote and page saying  it?
Scottish physicist Sir David Brewster (1781–1868)
Brewster, David (1815). "On the laws which regulate the polarisation of light by reflexion from transparent bodies".
Philosophical Transactions of the Royal Society of London.
This guy did his research  years before Tesla so Tesla must know this and came up with idea of
using this polarization not only for light waves but for EM too.
So why all  publications talk about ground currents (NORTON) and non of them mention Zenneck surface wave.
Sommerfeld, Arnold, "Uber die Ausbreitung der Wellen in der Drahtlosen Telegraphie"
(Tr. The Propagation of Waves in Wireless Telegraphy) 1909
Zenneck, Jonathan, "Über die Fortpflanzung ebener elektromagnetischer Wellen längs einer ebenen Leiterfläche und ihre Beziehung zur drahtlosen Telegraphie"
(Tr. "About the propagation of electromagnetic plane waves along a conductor plane and their relationship to wireless telegraphy") 1907
At Colorado Springs, in May 1899, Tesla, several of his assistants, and a local contractor commenced the construction of T
esla's laboratory shortly after arriving in Colorado Springs, Colorado
That means Tesla did it a decade before first theoretical paper has been published. Where we can find information related to this research.
Is it suppressed, lost , or it never happen.
Wesley
