d3x0r
Hello, long time no type...
@Wesley
I have a few ideas that I'd like some feedback on... my parent's recently bought a new property and I've been re-looking at ideas I've seen.
1.  The first was LED garden lights, using the ground as a single-wire-no-return conductor to remote coils and stepdowns to power LED lights for the drive path, and various... 1)
if There is a a large board with a lot of tuning forks that all resonate at the same frequency, doesn't that collecitively have more energy than none (although tuning forks would be unloaded,
whereas I'm putting LEDs on which would consume some of the energy)...
I haven't really seen anyone progress with a distrubuted ground-based tesla system... have you?
Cieling fans...
There's also these bladeless fans (truly bladeless, working much like a tesla turbine)
https://exhalefans.com/  they have a patent on it so... can't just produce these I suppose;
but the patent does seem overly specific, and with only slight modifications can fall outside it.
which then also reminded me to look into ' schauberger repulsine '
https://frankgermano.wordpress.com/viktor-schauberger-the-repulsine/
which instead of having a flat disk, has a disk with a sin-wave ripple in it.
considering the air flow of that fan though, the widening space as the radius increases,
I suppose (after refreshing on venturi effect) decreases the speed of the air moving laterally out as there's more space to fill, or
it would be lower pressure... higher tempurature I suppose.
But then, if instead of having flat disks, the disks were rippled, probably so each layer is 180 degrees out of
phase with the next so the chambers and gaps are smallest/largest instead of being parallel...
Air Multiplier...
So then a variation of that that, if you look up 'bladeless fan' actually goes to dyson fan
(which was invented 30 years ago by toshiba apparently [size=78%]https://www.telegraph.co.uk/technology/news/6377644/Dyson-fan-was-it-invented-30-years-ago.html
but never produced.... )  which isn't actually bladeless at all, but appears to be on the surface.
It is mostly a ring, with a chamber that exits a 3mm slit (velocity increase) behind a coanda foil with an open center.
In this open system, it is claimed to get 15x the airflow than the originating bladed fan... the narrow slit accelerates a
cylinderical air circle at 55mph(dyson) which then induces air in the center, as the coanda air foil expands the ring, creating a lower pressure,
which draws air in through the center of the ring.  Then additionall there's an entrainment of air on the outside as it draws air around the outside of the ring also...
(see really bad attached image...)
couldn't these be chained so a very small one x15 into one with a gap around the ouside into another pipe to another similar mulitplier.
Is this entirely useless because although the airflow is 15x it's at 1/15th the speed/pressure?
Being an open system, it's certainly not limited to a confinement...
Should be able to almost 3d print some really small replicas, and then just blow a little to start it, and it would sustain itself (should probably include a blocking off switch too...
And that brings me back to - so... can a current in a wire induce currents?  High frequency signals on the outside of a wire, and lower in the inside?
(I don't know... I don't see a way to get from the above hydro(fluid)-dynamic system to electornics in this case....
stivep
forks if  they vibrate mechanically than we dealing with F of sound and  longitudinal wave.
If direction of  the longitudinal   wave  energy  having the same vector direction can become sum  of vectors  than  Yes.
the energy of forks  will be concentrated  after all of the losses.
Wesley
d3x0r
The tuning forks thing is to liken many  exact same Inductance Coils/Capactance Toploads in resonance with an original generator...
stivep
Part #2
Quote from: d3x0r on September 09, 2019, 01:13:31 AM
Viktor Schauberger
https://youtu.be/yXPrLGUGZsw?t=2297
1. Kelvin Generator https://en.wikipedia.org/wiki/Kelvin_water_dropper
2.  Resonance Structures/Assigning Formal Charge
https://www.youtube.com/watch?v=fYCzeFEAfjg
conditions for resonance  look here  for 30  seconds only :-
https://youtu.be/fYCzeFEAfjg?t=410
comment
nitrogen  N in form of gas can be mechanically separated  from air.
2b.  .not  included in video  but helpful
carbon
QuoteCarbon (from Latin: carbo "coal") is a chemical element with
the symbol C and atomic number 6. It is nonmetallic and tetravalent—making four electrons available to form
covalent chemical bonds. It belongs to group 14 of the periodic table.  Three isotopes occur naturally, C and C being stable, while C is a
radionuclide, decaying with a half-life of about 5,730 years.  Carbon is one of the few elements known since antiquity
Carbon is the 15th most abundant element in the Earth's crust, and the fourth most abundant element in the universe by mass after
hydrogen, helium, and oxygen. Carbon's abundance, its unique diversity of organic compounds, and its unusual ability to form polymers
at the temperatures commonly encountered on Earth enables this element to serve as a common element of all known life.
https://www.bing.com/search?q=carbon&pc=MOZI&form=MOZCON
Wesley
Related Victor Schauberger Wirbel/Vortex/Swirl research :
https://www.google.com/search?client=firefox-b-m&q=pax+pacific+impeller&oq=pax+pacific+impeller&aqs=heirloom-srp..
" impeller can mix 4 millions gallons of water using only 150 Watts "
"butterfly"- Chaos-theory : how much energy as Brownian movement this 150 Watt can stimulate in 4 million of gallons( gallon  : ancient portuguese mass : 3,785 Liter) of water
http://egm-international.com/index_co2.htm  Vortex-/Wirbel-Wandler/Converter
https://en.m.wikipedia.org/wiki/Windhexe
Used Substantives /Nomen + deklination( Nom.,Dativ,Genitiv,Akkusativ,Ablativ,Vokativ). and Infinitives/Verbum+ conjugation( 1.Pers., 2.Per.,... Singularis/Pluralis + termination : Praesens,Praeteritum,Perfect,Plusquamperfekt,Futur I ,Futur II):
tornar = to turn = tourner = drehen = winden= vertere  Tornado/Vertex or Vortex
Wind/Vento/Bento and Gesch-Wind-igkeit= velocity /velocidade
velare, velo= round/rotation velociped from um-runden/rotieren/to round rotare  ( per second/minute/hour/....) Rotor
stare=estar( todifferfrom: ser) =stehen= to stand Stator Still-Stand E-/e-/state as social Nation and as statistical Situation/ Moment
The first "Neuzeit-Akademie der Wissenschaften""Physics" father- language has been Latin,
later German(Reichkanzlei zu Prag/Praha -Hochdeutsch
zu lithografische Institut/Duden-Hochdeutsch"= (hannoverische Welfen-)saechsisch=saxonic
/French/ Anglosaxonic(= english, no scottish/irish/Walsh = celto-iberic languages)
Who can not read original publication language and only trust to given by 2nds/3rd their hand. and mind translations get probably "dimensional" basic idea reproduction errors  !
Our thinking and as translation tool: spoken and written language is 4 and more dimensional like the assimilated
4 and more dimensional algometric humbots digital mind for the human-free industrial production. !
