0 Members and 78 Guests are viewing this topic.
jojo500
I wrote this befor  but ok let's try again.
kapadnaze as well as others made a great deal about  groundig in almost all demos they had a relativly new groundpoint.
bury a car radiator and what not .
ask your self how would you improvise a god ground ?
bury a car radiator ore driving an long copper ore zinked steel rod outside in the ground ? looking for a spot where you have moist earth? yes all fine .. they did this.
what else you need ?
a suficiente wire diameter at least 6mm diameter ore more and best be fine multistrandet . kepp the wire as short as you can
what did they? .. the ground point was allways like 10meters away from the demo unit away often the wire was way longer ... and they always used cable that looks like they stole it from grandma's old vakuumcleaner.
have fun
AlienGrey
Quote from: jojo500 on July 22, 2018, 12:19:32 AM
bury a car radiator ore driving an long copper ore zincked steel rod outside in the ground ? looking for a spot where you have moist earth? yes all fine .. they did this.
a sufficient wire diameter at least 6mm diameter ore more and best be fine multi-stranded . keep the wire as short as you can
what did they? .. the ground point was always like 10meters away from the demo unit away often the wire was way longer ... and they always used cable that looks like they stole it from grandma's old vacuum cleaner.
have fun
Isn't the wire length part of the wave length !n meters ?
AlienGrey
Quote from: TinselKoala on July 22, 2018, 04:01:16 AM
Auto self-tuning resonant circuit:
https://www.youtube.com/watch?v=JaPvdN75dl4
https://www.youtube.com/watch?v=AFP6c7lwyoE
Tinsel Hi can you tell me what label the scmitt-trigger inverter chip is please and what
iC2A and IC2B actually do and connect as IC2C looks as if it would control the width. It might be
of interest that a 4093 would be easyer to get hold of in the junk box and common the 2 inuts or
just common one input to +ve line.
Also some guys might find your circuit useful for driving a Tesla coil under Test if a diode is added
between the MosFet and coil and a voltage limiter between MosFet and drain and ground.
Some kind of current limit feedback might be useful under fault conditions.
Many thanks  ;D
PS Patric Kelly conference on alternative FE https://www.youtube.com/watch?v=2WXMZKqBP90
AG
Quote from: AlienGrey on July 22, 2018, 08:03:02 AM
Many thanks  ;D
AG
You must be talking about a different circuit than what I showed in those two video clips. The autoresonating circuit of TKoil X is very simple.
If you are talking about some of the other circuits others have listed above, I can explain the purpose of the chips if you specify exactly which diagram you mean.
