0 Members and 77 Guests are viewing this topic.
pix
OU is simple math. ;)
Signal of given amplitude "1" is feed to tuned resonator.
In Resonator:
Every pulse IN- amplitude is rising linear way: 1,2,3,4,5,6,7,8,9,10......
                       energy is rising expotential way:1,4,9,16,25,36,49,64,81,100......
During that period we feed 10 impulses into resonator, total energy IN :10
During that period in resonator amplitude rised to 10, accumulated energy rised to 100.
Cheers,
Pix
r2fpl
Quote from: a.king21 on April 26, 2023, 06:04:30 AM
The only odd thing that was mentioned was a thunderstorm on the day of the Aquarium 2 video.  Tariel said it was too dangerous to start the device in those conditions. Later on, the weather calmed down and the demonstration began.
It is not strange. After all, the ground wire runs to the ground.
I used to want to listen to submarines on low frequencies. I connected the ground wire directly to the mini plug as for a computer. The sound card and program worked very well. It was raining and lightning flashed. Not close at all and I didn't hear anything. I thought it was a temporary blackout but it turned out that the computer does not recognize the sound card. The sound card is dead.
The result is not a damaged output, but a whole sound card!
Why did this happen ? Because it is not true that energy is neutralized 100% by the earth. The Schuman Resonance is mainly the effect of thunderstorms that are even thousands of kilometers away.
Is my sound card damaged due to high V or high A?
stivep
Quote from: r2fpl on April 26, 2023, 10:20:44 AM
I have today few more minutes to respond.
Very interesting subject.
In page :Re: Wesley's  Kapanadze and other FE discussion forum is how energy  from lightning  gets into interface
and about ham radio. please go to the next page to read more.you can also start from here: Re: Wesley's  Kapanadze and other FE discussion forum
In page : Re: Wesley's  Kapanadze and other FE discussion forum there is  ready to use device to test A to B. at 137kHz Ham radio  band ( top capacitor must be  10 times larger.)
In page : Re: Wesley's  Kapanadze and other FE discussion forum there is explanation why  Kapanadze  grenade coil is so small and how to make our small.
In page:  Re: Wesley's  Kapanadze and other FE discussion forum there are  receivers  I used  for ULF. https://en.wikipedia.org/wiki/Ultra_low_frequency
more is in Russian here :
Re:   In Russian: Эксперименты по беспроводной передаче энергии, Доска Строителей
and in English here: Re: Wireless energy transfer experiments ,Builders board
_______________________________________________________
You computer sound card  should be  connected with  isolation transformer  to the ground or  your Russian heat system radiator
to make sure that doesn't blow due to  phase / ground improper connection  of your computer ( reversed) and/or leakage.
At best I would suggest to connect  entire computer  to the outlet using isolation transformer https://en.wikipedia.org/wiki/Isolation_transformer
at that point you are safe  to directly  connect output of your sound  card to the ground. You may try to use small capacitor  in between ground and  sound card.
If properly connected should be  working good as Rx although sensitivity is low so preamplifier  is recommended at IN.
I don't see how  distant lightning could damage it.
Wesley
sm0ky2
@Stivep
What does this device look like?
I have it here somewhere
I will be setting up my new lab in about a month or so
And all will be on display
stivep
I'm little confused  specify what you asking for please
Are you asking  about  isolation  transformer?
Wesley
