onepower
QuoteWell the signal comes from only 1 half of the 494 not both so if it's running from 12kh to 18khz the 4017 would only output
divide by 2 (input) and divide by 6 to 9  and then there is the 4013 divide by 2 again. some where around 1khz ?
But then whats the point of that ? but what it could do with a cap and resistor or two is test the PUSH PULL is running,
but I could think of an easier way to do that, but there again it's output goes no where! Oh and the logic is driven at 5Volts
But the TL494 could be run from 12 Volts or 24Volts, fun ain'it ?
I think you nailed it and after reading page after page of this nonsense, Ad nauseam I want to pull out my hair. It would seem common sense has left the building.
onepower
Hoppy
QuoteThat's most likely because its powered from the grid on a 'hot Wire' straight into the device!
Or a secondary coil such as a Tesla coil connected to ground can produce a net charge on it's surface while a secondary coil such as a Tesla coil not connected to ground can only produce a charge separation along it's length and not a net charge. This thing you cannot seem to wrap your mind around can be found in any high school textbook.
AlienGrey
Quote from: Hoppy on August 02, 2018, 03:36:56 AM
Maybe you can wrap your mind around and demonstrate how a TC can produce a continuous net charge without a power supply to drive it, whilst its 'top-load' is coupled to a grenade coil powering a heavy lamp load, also not being powered from a conventional power supply.
Hoppy I myself can do use and train my mind to do many things, and all my cats do many useful things
but I am have not as yet had occasion to see him (my top cat) do as you request  8) 8)!
I think you are asking for the meal to already made, but all the items for the meal are in this thread, Its just a question
of assembling the the individual items and then you can eat the meal. As you will already know many have found the meal already eaten.
As you might have guessed many of us are just back room boys and don't want to appear on stage eating our lunch!
AlienGrey
Quote from: Hoppy on August 02, 2018, 08:32:54 AM
So that's tantamount to saying the 'proof is in the pudding' in the modern sense of the phrase. I call your bluff on that one  ;D ;D ;D ;D ;D
Find your glasses and gloss over page 37 and READ IT !
TK and Hoppy  ;D ;D ;D
Our planet in electrical terms is a kind of spherical capacitor, charged to about 300,000 volts. The inner sphere - the surface of the Earth - is charged negatively, the outer sphere - the ionosphere - is positive. The Earth's atmosphere serves as an insulator.
Find a way to collect it !
