r2fpl
Quote from: Sergh on July 18, 2023, 05:36:04 AM
The same thing, buy a ready-made amplifier and do not suffer:
https://aliexpress.ru/item/1005005575276437.html
;D
We know many examples that one thing works differently in one than in the other ex. choke.
Sergh
Quote from: rakarskiy on July 18, 2023, 05:35:12 AM
The original screen sketch of the reactor, which is associated with Kapanadze.
I see the focusing of the magnetic flux from coils (by analogy with Russell), between which or inside of which coils (with a different number of turns) are inserted, connected in parallel. If a voltage is simultaneously applied to them, then a corresponding difference in magnetic intensities will arise inside these coils. Similarly, the EMF of the electric field will be greater from the side where there are fewer turns in the coils. Thus, if you follow the logic inside the channel throughout the entire sausage, there will be an EMF with a potential difference. The magnetic flux in the rings will provide focusing of the EMF (according to the ANAPOL system). The outer layer of thick wire will provide the pulsation of this sausage, thereby providing a change in parameters. The wire laid inside will have both eddy emf and commutation with earth load. Earth is needed just for the same purposes as the grounding of one phase of the output in electromechanical generators.
If my analysis is correct, it is a generator, a pulse generator with a corresponding reactor.
And you imagine that there are not ferrites but ferrite magnets from a magnetic separator or speakers. A Tesla bifilar are located between the magnets.
Then, disassemble the Li-ION or Ni-MH AA battery or search the Internet about its design.. There inside you will find a Tesla Bifilar. And the meaning is the same, as described by Tesla. Creates the same voltage between the "turns".
Then think about what the bifilar magnets will do when there is a current of 27 amps in the bobbin. Mechanical compression-stretching.
This is an apparatus for squeezing electricity out of a certain substance, which is located between the "turns of bifilars".
This drawing is safe for Kapanadze, since the formula for the physical and chemical process is not indicated. The correct option can be searched for 1000 years.
r2fpl
Am I the only one seeing ferrites here?
rakarskiy
I don't think Kapanadze has any kind of electrochemical reactor. He's got a purely pulse generator. The main thing here is obtaining of potential difference, movement and focusing of EMF around the conductor. Current force is already the result of another action, discharge of these received potential differences. In that "binoculars" (element #9) the resistance of the conductor where the current should be actually corresponds to zero value. So everything is very logical and very probable.
Sergh
Quote from: r2fpl on July 18, 2023, 06:00:14 AM
Look from the other side, a yellow sausage accidentally came out. Probably covered with masking tape or something similar. Disposable, only for one demonstration.
