Belfior
Quote from: TinselKoala on August 19, 2018, 07:51:25 PM
Well, perhaps there's a bit of translation loss here.
Anyone may do anything, that's true, but in order to draw conclusions, a real True Experiment should be performed.This involves a lot of brainwork before one starts twiddling dials and discharging caps and raising up earthworms.
So you need a testable hypothesis. Then you need to design experiments that actually test that hypothesis. Then you need to design control experiments so that you know what variables are actually influencing your results. Then you need to plan on doing your experiments enough times for statistically valid data to be gathered. Then you need to know how to analyze the data.
Often times in real academic research, the paper is written before any experimentation is actually performed, with the Data section using imaginary data and the Results/Conclusions written from both success and failure viewpoints. Then when the experiment is actually performed you just plug in the real data and massage the Conclusions part to match.
And one need not invoke the holy name of Tesla in vain. Just use the Scientific Method and you'll be fine.
Absolutely correct. This is the only way. Not just experimenting but also creating extraordinary eviden e. Not just measuring 20MHz RF with a DMM and claiming OU. First u need to claim the tests & results that would spoil your theory and then conduct them. Not just present "proof" that it works. People like their idea so much sometimes the proof is just measurement errors...
AlienGrey
Quote from: Belfior on August 20, 2018, 05:29:50 AM
Hmm interesting... is there a bemf acting against the charging coil? There should be in my mind at least. There is some inertia to beat. I would like to see some bemf circuitry schematics
In Tesla interview on Google he talks about it but it's igored, Donald talks about a massive pulse
Of ENERGY!
magpwr
Hi,
Can anyone point me any link  where i can purchase RG-56/U cable online which is sold by the foot in order to create a stiff Antenna which is also 8000Volts rated.
Thanks.
In return i am able to show something that no one in this forum have seen before anywhere relating to frequency up-scaling  after cable is converted to a Antenna and coil for tesla coil.
stivep
https://patents.google.com/patent/US690151A/en?oq=us20150102676
QuoteI have discovered that the south to north direction of the earth-current is maintained only when the plates: are of the same metal.
for these who are interested :
US20080191580A1  https://patents.google.com/patent/US20080191580A1/en
Example of active  above the  ground  positive counterbalance to  earth ground  utilizing telluric current
Wesley
Void
Quote from: magpwr on August 20, 2018, 10:12:43 AM
Hi magpwr. I don't know, but this company might be able to help you:
https://www.awcwire.com/part.aspx?partname=rg56
