AlienGrey
AlienGrey
Hoppy this might help why you don't under stand whats doing on, I hope it helps  :)
https://www.youtube.com/watch?v=fZjNJy9RJks
stivep
Kator01
https://www.youtube.com/watch?v=HJylD7xpEiU
first comment below the vid
ProfRaccoonvor 2 JahrenFinally, an independent experimental proof for Tesla's claim about a fundamental electrical earth resonance of about 12 Hz.. E explained this is not a Schumann resonance frequency of the earth-ionosphere cavity,  so the 11.77 Hz signal might  pass through the earth itself,  such that the 'ground'  frequency of 11.77 Hz  is higher than the Schumann base resonance frequency of 7.83 Hz. Assuming the electric waves all have the speed of light, then the Tesla ground resonance wave length must be much shorter than the Schumann resonance wave length. This rules out as well, that the 11.77 frequency signal is  Zenneck's earth surface TEM wave, since one should expect the ground frequency of such a wave to be close to the Schumann resonance (the ionosphere height is small compared with earth radius). So this test is a strong indication for longitudinal electric waves that travel through the center of earth. The earth diameter is about 12756 Km (measured from equator to the equator), and taking this length as exactly one wavelength, gives a frequency of 11.76 Hz (if one assumes the signal has light speed c= 300.000 Km/s ). It is very convincing (with respect to the claim that 11.77 is a natural frequency and not a system frequency) that two totally different Tesla coil systems with much different dimensions and system parameters both work optimal in case the spark gap frequency is tuned to 11.77 Hz.  Great work, E!
stivep
https://youtu.be/bBhVDcZwAls?t=223
This video starts from standing wave but it is worth to see it all.
Some useful links for thinkers: (Earth NMR) and more of nuclear processes
https://www.utu.fi/en/units/sci/units/chemistry/research/mcca/Pages/Sub-pages%20of%20Functional%20Materials/Applied-NMR.aspx
https://www.bruker.com/applications/chemical/analytical-chemistry/inorganic-chemistry.html
http://www.process-nmr.com/nmr1.htm
http://newscenter.lbl.gov/2014/08/19/nmr-using-earths-magnetic-field/
http://www.teslatech.info/ttevents/2018conf/2018ETCp09.pdf
https://en.wikipedia.org/wiki/Secondary_emission
http://www.jupiterscientific.org/sciinfo/numasses.html Neutrinos Have Mass for Sure
https://www.researchgate.net/post/Why_do_resonance_peaks_occur_in_a_neutron_cross_section_spectrum
https://en.wikipedia.org/wiki/Free_neutron_decay
Electrical and Earth/ impedance
http://www.hvpower.co.nz/TechnicalLibrary/RE+DS/Petersen%20Coils%20%20Basic%20Principle%20and%20Application.pdf
https://cr4.globalspec.com/thread/68715/Petersen-Coil-and-Capacitive-Charge-Current
https://uk.megger.com/electrical-tester-contractor-edition/october-2015/demystifying-loop-testing
http://www.erlphase.com/downloads/application_notes/Understanding_Sub_Harmonics.pdf
http://www.nlvocables.com/blog/?p=589 Measuring Telluric Currents – First Trial
http://scholarsmine.mst.edu/cgi/viewcontent.cgi?article=6061&context=masters_theses
https://www.solacity.com/docs/Polyphaser/Ground%20impedance.PDF
https://www.nemasurge.org/wp-content/uploads/2015/01/grounding.pdf
http://rexresearch.com/barbosa/barbosa.htm  Nilson BARBOSA / Cleriston LEAL Earth Energy Generator
https://patentimages.storage.googleapis.com/c2/73/cd/ed546d4872c866/US20150102676A1.pdf  METHOD AND APPARATUS FOR EXTRACTING AND CONVEYING ELECTRICAL ENERGY FROM THE EARTH IONOSPHERE CAVITY
https://patents.google.com/patent/US1974483 Electrostatic motor
asymmetrical capacitors and more
https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20040171929.pdf Asymmetrical Capacitors for Propulsion
https://www.researchgate.net/publication/2168167_Force_on_an_Asymmetric_Capacitor
https://en.wikipedia.org/wiki/Biefeld%E2%80%93Brown_effect
https://youtu.be/09otx2Pfphw?t=2042  Voltage multiplier ( I have two of  the units)
https://www.youtube.com/watch?v=bFssWFfFCFs Big  electrostatic ASSEMBLY .
Electrets:
https://patents.google.com/patent/CA2113048C/en
https://hypertextbook.com/facts/2008/JeffreyWong.shtml
http://iopscience.iop.org/article/10.1088/0960-1317/19/9/094003
http://aetherforce.com/electrets-permanent-electrical-magnets/
The old scientist: ( Negative Resistance) subject:
https://www.youtube.com/user/TheOldScientist/videos
https://www.youtube.com/watch?v=RRp2nipT-S0
https://www.youtube.com/watch?v=5X43sKFfRts Stanley Meyer's Electron Extraction Okki Moeljadi
http://www.analogzoo.com/2018/01/negative-impedance-converters/https://www.youtube.com/watch?v=DBteowmSN8g Lorenz Attractor - Physics 123 demo with Paul Horowitz
https://www.youtube.com/user/TheEngpjk/videos Patrick Kelly
https://www.youtube.com/watch?v=bBhVDcZwAls  TheMage00000
https://www.youtube.com/user/overunitydotcom/videos  overunity.com
Switching power supply:
https://www.youtube.com/watch?v=VLzcV9Sxt5Q Switch Mode Power Supply Measurements and Analysis
Simulation :(program tools)
https://phet.colorado.edu/en/simulation/legacy/capacitor-lab
Wesley
