0 Members and 112 Guests are viewing this topic.
Hoppy
Quote from: Belfior on December 30, 2018, 05:02:36 AM
maybe I'm stupid, but could somebody explain the papers or the idea, what makes this remarkable?
Just read them once, but it seems the idea is that 3 caps in series triple the amperage. I do believe, that the free energy is hiding behind something simple, but this made even me think like "whaaat!?!"
Then it uses the grid and barely lights a bulb. So not trying to put the idea down, but if someone could explain the principle?
Nothing remarkable. The series connected caps are charging so fast on the first phase, that the input bulb filament cannot heat quickly enough to glow. On the second phase, the transistor is switched on and the caps discharge into the output bulb.
Hoppy
v8karlo
The both circuits Zero and Q are made to show the principle and how it can be done.
Zero is showing multiplication.
Q is showing how can you use electricity and return it to source at same time.
The both devices are using same principle based on law of serial connection to raise the voltage of circuits.
I made Zero visual so you can see difference with your eyes.
It purpose is to change mindset of the people.
Make your Zero circuit and measure it while working.
Measure voltage on C1, C2, C3 while it works.
Can you fake the heat at output?
It is very cheap project which everyone can do.It is a starting point.
v8karlo
vasik041
Quote from: v8karlo on December 30, 2018, 07:30:18 AM
It is the right observation. Power trough L2 is bigger then trough L1.Remove C3 and work with C1, C2 only. The L1 will light up but L2 will light up more. You will still see the difference in power.
You CAN NOT fake the heat if there is no real power!
Do your experiments and change your mindsets.
There is only one small issue here. Power on L1 is NOT power consumed from power source. Current is not power.
