0 Members and 49 Guests are viewing this topic.
stivep
Quote from: lancaIV on January 02, 2019, 05:27:18 PM
Okay,  thanks a lot !
What I see is an "Experiment" period licence, expired.
What I see here is a relatively huge tower
https://www.waxahachietx.com/news/20180611/milford-testing-facility-tower-seeks-to-send-signals-worldwide
In relationship to "1000 W" transmitter power range.I hope that your "tower" is portable ! ;)
Sincerely -              OCWL
False assumption.
Small tiny  antenna that resonates at frequency X is equal in performance  to  huge antenna  at frequency X.
the only  difference is  in efficiency of that antenna.
However receiving antennas are more forgiving.
When your transmitter has high VSWR it just damages the Tx
When your receiver  has  impedance mismatch  it simply receives less.
Think about your car radio with broken antenna.
http://www.antenna-theory.com/definitions/vswr.php
Corum Brothers are not gods and their experience is much below Tariel Kapanadze practical experience.
Tariel theoretical experience is very low. He had no idea what he was playing with.
What they know  that they use.
First microwave was  at the size of  truck.
Please read my previous post again
I have made  some addition to it.
Wesley
stivep
Quote from: lancaIV on January 02, 2019, 06:03:48 PM
I do not conceptual understand your used expression " same performance" and your resume that it only depends from the efficiency.For me, following high fidelity devices, it depends from the receiver: thereby included tuner , equalizer and modulator, Amplitude + Frequency + Time Modulation .The antennas function:: tube or channel or " black/white whole"
I explained it in the link talking  about VSWR. Please read it, in my  previous  post.
So  it is not size of an antenna but impedance  match that makes an antenna  of any size to transmit energy.
The physical  aperture of an antenna is only important if you targeting  specific performance.
e.g. Your Far Field in given frequency at desired  direction.
You can use half wave  or quarter wave length of dipole antenna . But you can shorten  that antenna with baluns( shortening coils.) like G5RG
You can use the same length of wire  minus its capacitive wind to wind  factor coiled in coil.
It will work beautifully.  But now this antenna is very small.
As long as SWR is 1:1 or close to it.
However SWR 1:5 in receiver is still  excellent antenna.
That is why I said receiving antennas  are more forgiving.
Tesla coil is the coil. But you can stretch  HV coil wire and  it will work.
Now your traditional receiver has  sensitivity of 0.1uV in average.
That says only about receiver ability to process signals that are 0.1uV over the noise floor.
And that has nothing to do with the antenna.
Antenna is independent creature good or bad for you at given frequency  range.
And its gain is measured  with db (Decibels .)
I must totally disagree with you . Antenna is not the filter.
It does not block anything it only resonates or not.
And it has bandwidth with one particular highest frequency of its resonance that gives you the highest  level of the signal  in TX or RX.- with proper impedance match.
-or the highest gain.
I'm just insignificant  member of shadows of  the crowd.
Wesley
Void
I told you guys before what I think Mr. Kapanadze's secret is, but for some reason
no one believes me.
seychelles
mr kapanaze secret is to understand that the earth and the atmosphere is an actively
charged asymmetrical massive capacitor. what most people fail on is that you have to have
a massive ground system, because that is where the mass of the charge current is coming from.
this guy explain so clearly even a carpenter can understand it.
https://www.youtube.com/watch?v=yk4CJLjNwfQ&t=3s
Moin Moin or Good morning ! The light-wave frequency oscillation spectrum has his "trinity": in Units( included pseudo-) eV, dB and nm.
Next :
https://en.m.wikipedia.org/wiki/Harmonic
Caution the meaning differences : https://en.m.wikipedia.org/wiki/Harmonic_(disambiguation)
and
classical physics-"philosophy" :
https://en.m.wikipedia.org/wiki/Laplace%27s_demonhttps://en.m.wikipedia.org/wiki/Maxwell%27s_demon
  What means " Paradigma, Axiom" in a Meta -World?
