0 Members and 44 Guests are viewing this topic.
Void
Quote from: lancaIV on January 04, 2019, 02:41:28 PM
To get an idea about possibilities:
  https://worldwide.espacenet.com/publicationDetails/biblio?CC=US&NR=5590031A&KC=A&FT=D#
Hi lancaIV. That is an interesting patent. They claim their device will convert 'high frequency zero point
electromagnetic radiation energy to electrical energy', and their patent was granted (US5590031A).
https://patentimages.storage.googleapis.com/37/c6/ba/566c00e9b0f513/US5590031.pdf
They use two dielectric spheres.
"Abstract
A system is disclosed for converting high frequency zero point electromagnetic radiation energy to electrical energy.
The system includes a pair of dielectric structures which are positioned proximal to each other and which receive incident
zero point electromagnetic radiation. The volumetric sizes of the structures are selected so that they resonate at a frequency
of the incident radiation. The volumetric sizes of the structures are also slightly different so that the secondary radiation emitted
there from at resonance interfere with each other producing a beat frequency radiation which is at a much lower frequency than
that of the incident radiation and which is amenable to conversion to electrical energy. An antenna receives the beat frequency radiation.
The beat frequency radiation from the antenna is transmitted to a converter via a conductor or waveguide and converted to electrical energy
having a desired voltage and waveform."
It is interesting, but Mr. Kapanadze does not seem to use two dielectric spheres or other such dielectric structures.
Void,  Kapanadze: Impedance matching network here
Mead, Nachamkin: beat frequency circuit and transformer
It is to compare and to search and find the easiest way to get "common" DC or AC current.
stivep
Quote from: Hoppy on January 04, 2019, 04:52:05 PM
Thanks Wesley. The Kapanadze green box device lamp load is connected between the ground wire (running through the centre of the antenna / grenade) and one end of the antenna winding - see attached clip. This does not make sense to me in relation to the schematics you posted in your reply to me. Can you explain this please?
I'll  try.
There are  many ways to receive  surface wave.
Viziv page shows three different concepts.
Tariel Kapanadze used  at least 5 different concepts.
The common factor for all of that from Viziv and Tariel together  is the means  of tuning.
Note: I have seen  green box only  on video.
Note: second picture is  related only to that  particular concept
Word rotation means  change of angle only.
Note: original patent application  of Corum Brothers says:
about CW/CCW winding !!!!! read it you'll see it.
They knew about it.
Wesley
stivep
Quote from: Hoppy on January 04, 2019, 06:24:47 PM
Thanks Wesley. However, the kapanadze load is misplaced in respect to your crossed representation because the load is in series connection with the one leg of the antenna and the ground wire.
look at  picture 12a you have series  connection.
just cut out impedance matching box as if it  did not exist.You use it only if you need it.
You can do  the same with 12b
There you go
You may still call it parallel but  it is series with respect to ground
You may say there is no ground.
Than think about counterpoise.
Kapanadze concept was much more advanced but it was very unstable and highly reactive.
Kapanadze was trying to move his device only in vertical axis Y. Walking with it would ruin his show.
I did the same here with placing dielectric on the top of another.
https://youtu.be/KLAPRNWuAn4?t=1174
and not to much.
Wesley
stivep
I decided to  make comment ,
https://patents.google.com/patent/US4751515A/en
contra-wound
combined
= CCW/ CW = Kapanadze coil
Wesley
