Kapanadze and other FE discussion
Started by stivep, May 26, 2018, 01:48:55 PM
0 Members and 54 Guests are viewing this topic.
kolbacict
stochastic resonance is interesting ...
they say that a normal (casual) :)varicap transforms the thermal noise voltage into a potential difference across the terminals. It is too small to measure with a microvoltmeter, even with an input resistance of 1MΩ.It accumulates on the parallel condenser for a minute, then connects to the device. I tried, I did not succeed.  Why?
mkjekyll
Kol, you want to harvest Johnson noise, in that case everything has to be tuned to the gnats ass and all parts need to be extremely high tolerance and RF layout rules on the boards has to followed and a really crappy resistor or some other better  source needs to be used such as a spark gap and then one is building the TK device .
For thermal harvesting one would be better off growing some IR antenna 1/4 wave resonator and making a rectenna than one would harvesting thermo noise the way I envision from your question.  Better off with a temp differential like a wellhole and the sun and simply use Peltier junctions
Stochastic resonance is actually what is happening with the spark gap switch, lots of energy in a little spark and a great seed to pertubate the local out of equilibrium...
The varactorp diode is simply a pump and the same can be accomplished on the B side with a variometer or it's analog which could be a piece of Terfenol D used properly
