Kapanadze and other FE discussion
Started by stivep, May 26, 2018, 01:48:55 PM
Sergh
Quote from: lancaIV on September 30, 2023, 05:55:00 AM
personal,individual,freedom
' Made in ...'
U.S. Republicans and Democrats
Hollywood,actors on strike...
If this style seems progressive to someone, then my opinion based on your postings is this:
- completely offtopic. No information regarding Kapanadze's devices or Wesley's research.
If I started dragging info scam from the Internet into all topics, the forum would be torn to pieces.
We are not enough old to descend to the level of conversation between two senior in a pub.
Wesley, please act as a moderator.
stivep
1 drop of water may turn into powerful explosion.
To save you time I will point  at material that can be skipped or partially viewed.
______________________________________
The phenomena is largely unknown to engineering community and totally  unknown  to most of the audience here.
Quote:
History of Water Arc Explosions
QuoteThe unusual strength of explosions caused by a pulsed current flowing through water plasma was first noticed in 1907
by Trowbridge [ 11 in his early high voltage laboratory at Harvard University
explosion is not caused by heat and steam  ! and can easily cause rock fragmentation !
more of it is in the link:_Water_Arc_and_Dielectric_Breakdown/Granea The Anomalous
__________________________________________________________________
1. First video to watch for 1 minute only.
Dr Jaynes:
https://www.youtube.com/watch?v=-aGecOw5UKQ
2. second video to watch for 1 minute only.
https://www.youtube.com/watch?v=YyBahrxRxNw
3. third  video to watch is
You may watch it fully but if you want to  get to specific than watch from here :
https://youtu.be/qkLGSCXOxi8?t=732
The subject is related to catastrophic explosions in power  line transformers, houses, people next to electrical circuits, street manholes etc.
Right  amount of water  drops  into the spark triggers the phenomena.
I may present  you more material  later and formulate questions and comments.
I may also decide to delete this particular comment, - will see...........................
This article provides  partial answer to  Kolbacict   question formulated  by his  curators week ago
when, why, and what .
-in relation to resonating load, if we  use A to B energy transfer to an object that at some point of its internal structure
will always have the required conditions - especially related to  objects at the surface of the sea.
Wesley
Sergh
Quote from: stivep on October 02, 2023, 07:43:20 PM
Dr Jaynes:
Hello Wesley!
Thank you for writing messages relevant to the topic.
Regarding capacitor discharges in water.
This direction was discussed on free energy forums. In the ex-USSR environment this is called the "Yutkin Effect".
https://habr-com.translate.goog/ru/companies/ruvds/articles/556530/?_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=en
Here is Yutkin's .pdf book  about various types and technologies of discharge in water, you can download the file and translate it via Google Translator as a "Document":
http://bourabai.ru/library/elektrogidravlicheski_effekt.pdf
About Dr Jaynes video of capacitor discharge
From the video it is clear that Dr Jaynes uses a 2400 microfarad capacitor, charged to a voltage of 330 volts. Using the formula for calculating the energy of a capacitor, we obtain a discharge energy of 130 Joules. This is quite a lot of capacitor energy.
As a child, I played with capacitors, discharging them with a screwdriver. I can tell you with 100% confidence that if you discharge such a 2400 microfarad 330 volt capacitor with a screwdriver, there will be a very loud sound and a lot of sparks. The sound will be so loud that you may go deaf for a while.
And all this WITHOUT WATER!
The mistake of Dr Jaynes is that it was necessary to make video about discharge of the same capacitor, charged to the same voltage, with the same electrodes, but without water. Just short-circuit the electrodes with a piece of metal. I'm sure the effect would be the same. However, you can search for discharges of capacitors similar in voltage and capacitance on YouTube or experiment yourself, observing safety precautions. After several such discharges, the capacitor will probably become unusable. Internal connections may melt and break.
For example, here you can see a discharge capacitor with 2 times less capacity and unknown voltage charged:
https://youtube.com/shorts/MQ8_zJmTabs
It is the basic rule. If you have obtained some interesting effect and explained it theoretically, then remove the main element and repeat the experiment. If the effect remains the same, your theoretical explanation has been proven wrong.
My conclusion: - Simple capacitor discharges in water are unlikely to be a source of free energy. But:
1. Similar discharge can be used as a tool for creating high pulse pressure for other areas of searching for free energy. This is something I thought about earlier. The problem is that the capacitor discharge needs to be serialized somehow. Significant energy consumption.
2. You can use a capacitor discharge in a nanostructured substance. To make it clear, for example, a discharge in wet wood or even in a cucumber or melon. Funny. But, cellular tissue consists of many ultrathin membranes. With a sharp short pulse of current, an ion shock occurs on these membranes. Anything can happen here. According to rumors, LENR was expected. Short powerful pulses are needed, with enough energy to balance at a level sufficient for LENR but not enough to burn the membranes.
Expected form of free energy:
- low-temperature thermal energy, up to +40 degrees Celsius. If you try to get a higher temperature, the membranes may cook and become unusable.
- low-voltage current pulses, much longer than discharge pulses.
kolbacict
Quote from: Sergh on October 03, 2023, 04:27:11 AM
Is it possible to make diamonds using this method ?
Let's make diamonds, lots and lots of them. Then I'll go to New York and buy out Wesley's laboratory... 8)
stivep
Sergh thank you very much - fascinating subject.
I do thank you for  your contributing material.
If you  have the original link to Dr Yutkin  translation you posted I'll be happy to read it.
Please post it . Russian language is no problem for me any longer.
https://ru.wikipedia.org/wiki\
The audience here  doesn't yet see the importance and  value of it, I think.
On the other hand some application of it  may not be suitable to be publicly  discussed, unless we switch
into a very much technicality of it.
Here is the example of  format of technicality comfortable to be used in this forum:
It was increasingly thrilling to look at DUT behavior  similar to that  presented in video, but its culmination was
looking at the same DUT from the distance of ~5 km with use of  "A to B."
No significant losses were  noticed, even  more - we were  under impression  that something is amplifying the effect.
We didn't  have time to try it in Costa Rica., but  I ordered it to be tried in Baltic sea .
They couldn't  conform  if there  was  "amplification" but I was told that  for an eye it look shockingly unexplained.
At land  there were cameras and  watching the load (DUT) technician, but effect at sea is many times stronger or just look stronger
many times. Salinity  of the water helps "A to B"  over distance but  The  same DUT at sea simply vaporized.
The first test  was provided along the coast line  Gdansk, Gdynia, Orlowo in Trojmiasto - this was easy :
Test A -  coast to coast over curvature. No  deep water, relatively  quiet surface between "A to B" distance more than 5km in line of sight
              ( not to many people walking on the sand )
Test B-   the second test was   coast to sea - actually not  exactly like that - there is curved coast line  but DUT was at sea.
   That is one of the reasons I  become interested with Salt Lake City:- easiness of  any tests.
   https://www.utah.com/destinations/natural-areas/bonneville-salt-flats/
Russia or  Uzbekistan ( the most perfect  test site) is not accessible to  me for obvious reasons.
opinion expressed is  my own
Wesley
