IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
George1
Let us push forward together the technology progress!
Let us popularize the link  https://www.youtube.com/watch?v=xX14NK8GrDY  in any possible way! Because the link https://www.youtube.com/watch?v=xX14NK8GrDY contains an absolutely free new technology information, which is able to make better the life of any human being on Earth!
1) Having in mind the link https://www.youtube.com/watch?v=xX14NK8GrDY  assume that:
a) Ma = 1 kg;
b) Mb = 4 kg; the value of Mb can be either increased or decreased as many times as you want;
c) V1 = 1m/s = const;
d) Ffr. = force of friction inside the zigzag channels = 0.0000001 N; the latter can be further decreased as many times as you want;
e) N = number of zigzags = 10; the value of N can be either increased or decreased as many times as you want;
f) Shapes of the zigzags = sinusoids; the latter can be replaced by any other curve patterns.
2) It is evident that if V2 = 0.6 m/s and if V3 = 0.1 m/s, then (a) the law of conservation of linear momentum is valid and (b) the law of conservation of mechanical energy is invalid.
3) It is evident that if V2 = 0.8 m/s and if V3 = 0.3 m/s, then (a) the law of conservation of linear momentum is invalid and (b) the law of conservation of mechanical energy is valid.
4) It is evident that (a) the law of conservation of linear momentum and (b) the law of conservation of mechanical energy are invalid simultaneously in this special particular zigzag case, which is described in the link https://www.youtube.com/watch?v=xX14NK8GrDY  .
George1
Let us popularize in any possible way the link https://www.youtube.com/watch?v=xX14NK8GrDY  as it contains an absolutely free new technology information, which is able to make better the life of any human being on Earth.
a) Ma = 1 kg;
George1
Asking our two simple questions for the 32nd time.
1) Consider carefully and thoroughly (and many times!) the link https://www.youtube.com/watch?v=xX14NK8GrDY  .
2) Assume that:
a) Ma = 1 kg;
3) It is evident that if V2 = 0.6 m/s and if V3 = 0.1 m/s, then (a) the law of conservation of linear momentum will be correct and (b) the law of conservation of mechanical energy will be incorrect.
4) It is evident that if V2 = 0.8 m/s and if V3 = 0.3 m/s, then (a) the law of conservation of linear momentum will be incorrect and (b) the law of conservation of mechanical energy will be correct.
5) Or may be both (a) the law of conservation of linear momentum and (b) the law of conservation of mechanical energy are actually incorrect simultaneously in this special particular zigzag case?
So let us ask again our two simple questions for the 31st time.
QUESTION 1: V2 = ? (How many meters per second is V2 equal to?)
QUESTION 2: V3 = ? (How many meters per second is V3 equal to?)
Looking forward to your two answers for the 32nd time.
George1
a) Ma = 1 kg;
Let us popularize in any possible way the link https://www.youtube.com/watch?v=xX14NK8GrDY  as it contains an absolutely free new technology information, which is able to make better and easier the life of any human being on Earth.
George1
Asking our two simple questions for the 33rd time.
2) Assume that:
a) Ma = 1 kg;
3) It is evident that if V2 = 0.6 m/s and if V3 = 0.1 m/s, then (a) the law of conservation of linear momentum is valid and (b) the law of conservation of mechanical energy is invalid.
4) It is evident that if V2 = 0.8 m/s and if V3 = 0.3 m/s, then (a) the law of conservation of linear momentum is invalid and (b) the law of conservation of mechanical energy is valid.
5) It is evident that both (a) the law of conservation of linear momentum and (b) the law of conservation of mechanical energy are invalid simultaneously in this special particular zigzag case, which is described in the link https://www.youtube.com/watch?v=xX14NK8GrDY  .
So let us ask again our two simple questions for the 33rd time.
Looking forward to your two answers for the 33rd time.
