IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
George1
To nix85.
Very interesting! Some pictures and/or videos related to this two-swords experiment? To copy and repeat it one-to-one?
George1
To nix85.
Some instructional pictures and/or videos related to this two-swords experiment? May be there is some secret here? Маy be it is better if we аsk a professional athlete to carry out this rotational experiment?
George1
To lanca IV.
Some English versions/translations of the three links' texts? Seems to be interesting, but no member of our team speaks German.
https://translate.google.com/translate?sl=auto&tl=en&u=http://www.evert.de/ap0604.htm
this pdf http://www.borderlands.de/net_pdf/NET0904S25-30.pdf
to cut each page  = too large for the translator https://translate.google.com/?hl=de
for example first page :
As can be seen from the introductory texts by Würth AG, the focus of their research and development work is on the generation of energy from gravity, centrifugal force and inertia1. The inertia-active swing systems developed by Felix Würth are intended to utilize the effects of self-acceleration, as they also occur in cyclones, hurricanes and tornadoes. According to his theory, such machines vibrate in an open natural system and resonate with gravity. In the first phase, various types of gearboxes were developed that achieve a power boost of 200% and more. The inventor assumes that amplification factors of 700% to 800% can be achieved with appropriately further developed systems. The following article shows that it is possible to achieve such effects for certain periods of time, provided that energy is temporarily stored in the system, e.g. via flywheels. Whether and to what extent an energetic effect also plays a role in addition to a verifiable increase in torque and power is an open question. Conventional scientific analyzes show that in a closed mechanical system - unlike in complex energy conversion systems such as hurricanes - generally none continuous energy input is to be expected. Since, however, not only Felix Würth, but a whole series of other inventor systems of a similar type, partly also in combination with electric motors and generators - see also the following article - have been set up and successfully tested September / October 2004 Volume No. 9, Issue No. 9 / 1025NET-Journal it cannot be ruled out that a clever combination of mechanical and electromagnetic resonance systems may involve new types of energetic energy conversion processes. Open and closed systems Felix Würth emphasizes on his website that he is very well aware that a perpetual motion machine is not possible. However, he emphasizes that the principle of the conservation of energy only applies to closed systems, but that his system is open. In physics, "open" is a system that can exchange both energy and matter (or particles) with the environment. An example of an open thermodynamic system is an open cooking pot that exchanges both energy in the form of heat (from the stove top) and matter in the form of water vapor with its surroundings. A system is defined as closed (not closed!), Which can exchange energy but not matter (or particles) with its environment. An example of a closed thermodynamic system is a pressure cooker that absorbs and radiates energy in the form of heat, but cannot give off any water vapor. A system that captures, for example, electromagnetic radiation, gravity or neutrino radiation and transforms it into another form of energy, also belongs in this category. Finally, there are also completely closed systems (at least in the imagination) that have no interaction with the environment. Such a closed or isolated system can neither exchange energy nor matter with the environment, i.e. the energy and matter present in the system remain constant. This clearly means, for example, that no volume work can be carried out on a system or that no heat exchange takes place. In technology, one speaks of a closed system when the external forces are negligibly small compared to the forces in the system. Efficiency, performance figure and "Over Unity" When assessing new types of energy machines with high efficiency, it is important to use clear terms3. We are guided by the explanations given by Dipl.-Ing. Andreas Hecht has summarized on the website "borderlands.de". In every physics book there is an explanation that the efficiency is to be understood as the ratio of the output to the input power. For reasons of convenience, efficiency is sometimes also expressed as the ratio of two (physical) jobs. Because of the inevitable losses, the efficiency is always less than one, than less than 100 percent. With the invention of the heat pump, one faced a problem: the power supplied was less than the output! Of course, no energy was 'produced' here either, but you needed a term to describe the relationship when energy is not only supplied, but by a process
Otto Stein his book as pdf  https://www.yumpu.com/de/document/read/20184764/otto-stein-die-zukunft-der-technik-pdf
not automatic translationable  :'( only by a manual translator typing  :P ,classical standart  ::)
or learning Deutsch or knowing someone with good Deutsch-Kenntnissen and dolmetsch-ing potential ! ;)
Sincerely
OCWL
George1
To lancaIV.
Thanks a lot! Need some time to consider carefully everything you have sent.
