IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
nix85
you are totally missing the point, this has nothing to do with hanging
and yes, you can theoretically get to near light speed with this simple principle
but why go to such extremes, its enough to say 3h to moon at 1g
with half way deceleration can be easily accomplished
in fact you could have a spacecraft that could constantly cruise around
the moon and earth as a hotel with minimum energy for inertial
drives provided by OU magnetic generator or solar panels
George1
The link below describes a few simple experiments, which break the law of conservation of mechanical energy and the law of conservation of linear momentum. You can easily carry out these simple experiments in your garage as many times as you want.
And here is the link:
https://www.youtube.com/watch?v=xX14NK8GrDY&ab_channel=PeterAxe
IMPORTANT NOTE 1. It is highly recommendable that the above mentioned experiments  are evaluated and realized by a highly qualified expert (Ph.D.) in theoretical and applied mechanics.  Otherwise nothing will come of it (most probably).
IMPORTANT NOTE 2. The key question in the above mentioned experiments is how to reduce standard friction (where necessary) to a certain minimum limit, beyond which the experimental error (due to friction) is small enough and can be neglected. The answer is simple. You can use for example permanent magnet slides as shown in the link https://www.youtube.com/watch?v=NoW0A8hYs5A . (Permanent magnet slides reduce friction practically to zero and the measuring devices do not register any force of friction.) Aternatively you can use hundreds of other methods for reducing of friction (as much as necessary) as modern technologies allow this feat. We live in 21st century after all.
Looking forward to your comments after repeating the above mentioned simple experiments.
SIMPLY CARRY OUT THE EXPERIMENTS! WHERE ARE THE SKILLFUL EXPERIMENTORS HERE IN THIS FORUM?!
George1
Please look again at the link https://www.youtube.com/watch?v=xX14NK8GrDY
1) The violation of the law of conservation of linear momentum, which is described in the link above, can be used for a substantial decreasing of the recoil of any standard firearm as this does not influence in any way this standard firearm's range. (Besides in principle it is possible to use the new mechanical effect several times in a row thus reducing the recoil practically to zero.)
2) The violation of the law of conservation of linear momentum, which is described in the link above, can be used for designing of an entirely new kind of a shock-absorber. The latter can be installed on any vehicle thus saving human lives and/or preventing injuries.
Looking forward to your answer.
