Free Energy is IMPOSSIBLE without this, why everyone fails!
Started by aether22, July 24, 2018, 12:32:48 AM
forest
Again you are correct about motor--generators but in ordinary generator threre .is a aether input also or they would be as inefficient as the original Pixii od Clark dynamos. There is no way they work by energy conversion from mechanical inout only but to prove it a large money is required.
AlienGrey
Can you cut to the chase, what is your missing ingredient ? anddon't say an electric motor please !  :o
Acca
So it's quite refreshing to see that Eather is the main source of matter that is invisible and it is the source of traction for gyroscopic effect as all these patents from 1900's to the present show unidirectional vector movement against an invisible force....in a vacuum of space and with out gravity effect. go figure out how that is possible without Eather.
Standard physics is a a loss to explain the twisting of a rotating wheel 90 deg. all they say it's an effect.. Great !
Pulling yourself against vacuum of space by using a a rotating mass makes no sense without traction...Remember Newton, action and reaction are imprinted in teachings of science..  Hello... Eather or whatever that is "X" is..
Take a look at the latest photos from Hubbel telescope, trillions of galactic objects ....it will blow your mind..
Acca...
aether22
Quote from: AlienGrey on July 24, 2018, 02:10:31 PM
I will tell you the missing ingredient, it is building a device that develops aetheric energy.
But before I go into it, here is a post I wrote to someone that might prove useful...
Have you considered that these Free Energy devices create anomolies such as cold current...
Non-shocking current...
Spontaneously charging things...
Arcing at low voltages
Incandescent bulbs glowing off colour
Sometimes demonstration of anti-gravity...
Sometimes low voltage DC completes in open circuit...
Sometimes materials becomes changed...
Sometimes energy fields manifest around these devices...
Have you considered that if something very different is happening from what conventional electromagnetism predicts, maybe it isn't conventional electromagnetism?
Have you considered maybe it's not a coincidence so many devices have a circular nature...
Have you considered that maybe Tesla was right...  Maybe Wilhelm Reich was right...  Maybe Konstantin Meyl was right...
Maybe Moray was right...  Maybe Stubblefield's crazy achievements which make no sense conventionally, maybe Keely's achievements are based of what they are obviously based on?!  Maybe Searl was right, and Hamel, both demonstrating Free Energy and Antigravity...
You have been looking in the wrong place if you have been focused on trying to make a bootstrap device based on conventional electromagnetism, that only EVER leads to conventional results.
Free Energy research is full of accounts involving anomalies, simple devices doing not just one impossible thing, but 2 or 3 or more!
Look at Sweet, look at Bedini, look at Gray, look at the Adam's motor, none of this stuff has just Free Energy, there are other anomalies!    That's because they are engineering the medium of matter.
Of course who could work out how these disparate device work, who could see the commonalities in them, the correlations and see the underlying aetheric science, the aether that you cannot buy a meter for?   It seems almost hopeless, except I spent roughly 24 years finding out how!  I can help most people feel the aether and tell you how it works, what the correlations are and take you through it.
So, the aether is the key.
So, what should you do about this info?  Ignore it?   Or change course?
To convince you it is worth changing course I am willing to "PROVE" to you that what I am talking about is real!
But, there are no meters that can detect aetheric energy and if there were it would be of little use, there is too much going on, a number on a meter would be of little value.
But I assert that 90% of the general population can feel this energy to some degree, though that can go down or up depending on the type of person.  Some Audiences might only be 50%, but at any rate I cannot Guarantee you will be able to feel energy, but I can however assure you that if a number try you might become reasonably convinced from others feeling it, either at your place, or online.
The second promise I make is that there are guidelines for involving the aether, small details and techniques I can tech you that are near effortless to include the are not detrimental to the conventional operation of an electrical device that can make a BIG differences to the aetheric functionality.
If you are willing to try things and don't need proof, I could just give you these techniques, I could tell you about a hundred of them!
Adding some aetheric components to a circuit is not guaranteed to trip it into a OU operation, but it will take it in the right direction generally.  Aetheric techniques/components don't all fit together in a sense of "more is better" and i will try to give understanding as much as I have gained as to what the deal is.
AlienGrey, if you want to know how to make aetheric energy work, tell me what device you have sitting around, under test or collecting dust you would consider lightly modifying (probably in entierly reversible ways) and I will see what techniques I have found could be tried.
Or you could make the "aetheric inductor" I posted in the other thread.
Or you could ask me for an alternative coil you could make to possibly feel energy from.
loner
Quote from: aether22 on July 24, 2018, 08:22:21 PM
I have a anomaly when i charged two aluminum plates with 300VDC. About one feet away i have a
detector for AC (100-600VAC). It light up even tho i have no AC. At least 100Vac detected. Further
away it light up when i touch it.
