Self-Powered Generator - Inventor From South Africa
Started by SkyWatcher123, August 11, 2018, 01:18:43 AM
SkyWatcher123
Hi all, had a chance to test some bearing lubricants today.
I tried only graphite powder, by using fine sand paper against some compass graphite pieces and placed the powder into the bearings, that worked decent, spun fairly freely, though the noise level was still not to my liking.
Then I tried the  3 in one motor oil, equivalent to SAE 20  and that is working very well and the noise is much less.
Not sure what kind of oil is in that household oil can, maybe it's a thinner oil.
So now that the noise issue is acceptable, will work on the other coils.
peace love light :)
RoliK
Thxs for update! We are using WD40 to clean our bearings.
Best wishes, Roland
SkyWatcher123
Hi rolik, thanks for the reply, Does this mean you are experimenting with this south african device.
I finished the 4 coils and now am working on the circuitry.
peace love light :)
SkyWatcher123
The generator variant is finished, at the least for now, may add more coils later, depending how it goes.
I am running some simple 1 to 1 charging tests for now and logging the data.
peace love light :)
SkyWatcher123
Hi all, interesting results so far.
Though I had to use a darlington pair, using 2 NPN transistors, because previously with the single transistor, I had to use a 68 ohm base resistor to get proper transistor triggering.
Now I can use a 10 Kohm base resistor and the rpm's are a little better and the input went from .11 amps down to .055 amps.
Will continue these basic 1 to 1 charging tests with this new configuration.
peace love light
