Self-Powered Generator - Inventor From South Africa
Started by SkyWatcher123, August 11, 2018, 01:18:43 AM
SkyWatcher123
Hi all, Hi rolik, here is the oscillator, each mosfet has 100 ohm gate resistors
and each source pin has 56 Kohm pull down resistors.
Transistors are SSF45N20B
200 volt, RDS .065 ohm
26.4 amp continuous
peace love light :)
SkyWatcher123
Hi all, I'm testing the south african type device again.
I'm only using one bifilar drive coil and 3 separate generator core/coils.
Using the 3 separate core/coils to power a 12 volt led bulb and create a mechanical load, to see if the batteries will still maintain voltage and charge.
Led bulb is connected to full wave bridge with 1.5 farad car audio capacitor for smoothing output.
So far, it is looking positive.
Have run 13 cycles, swapping 12 volt tractor battery with each cycle and giving rest period in between cycles, most of the time.
Starting rest voltages:
Battery A = 12.65 volts
Battery B = 12.70 volts
Total hours run time so far = 13.5 hours or 70 watt hours used, as drive circuit draws 5.2 watts.
After 9 hours system run time, overnight resting battery voltages:
Battery A = 12.695 volts
Battery B = 12.655 volts
After 12 hour system run time, 4 hour resting battery voltages:
Battery A = 12.64 volts
Battery B = 12.735 volts
Your positive thoughts welcome.
peace love light
erfandl
Hi SkyWatcher. thanks for sharing the result. looks like the result is good and the output battery getting charged while consuming energy! so we have an overunity device ? I start to building the 150 watt South Africa generator with 10 coils
Turbo
Theres no way a mosfet is handling 26.4 amp without a heatsink.
That thing will go up in smoke within 5 seconds.
gyulasun
Quote from: Turbo on November 14, 2018, 03:38:02 AM
Yes but the 26.4 Amper is taken from the data sheet of his MOSFET.   ;)
http://pdf.datasheetcatalog.com/datasheet/fairchild/SSF45N20B.pdf
