Self-Powered Generator - Inventor From South Africa
Started by SkyWatcher123, August 11, 2018, 01:18:43 AM
gyulasun
Well, you are free to make any coil combinations so that the induced voltages should sum up.
As per common logic if all the coils are positioned with the same identical winding sense,
then their induced voltages should sum up.
The 1.2 volt resulting between coils 6 and 8 may indicate one of them should be flipped by its wires.
I assume you have 5 rotor magnets, right?
Gyula
erfandl
Quote from: gyulasun on December 05, 2018, 06:37:36 AM
Gyula
thanks. the motor will not starting automatically. I must handle the motor with hand. also the motor rotating to both sides !
yeah the rotor have 5 magnets. all N side is out. the hall sensors are installed in coil 1 and coil 4
gyulasun
Well, it is "normal" in this setup that you have to start the rotor by hand because all the 5 magnets
strongly attracts to the 5 bolts they are just facing, this is inherently so in this arrangement.
doktorsvet
 erfandl,
If not difficult, draw a diagram of the connection of the coils.
I myself did not read how it was done in Africa, but you can start the reverse EMF in a circle...
For this you need to leave 5 magnets, and put the coils 6.  :D
Ed morbus
