Rychnowski, the man who condensed the ether
Started by franco malgarini, August 21, 2018, 07:40:50 AM
Fernandez
I like the phrase: Condensed the Ether. So this is a good landing spot for this rambling.
Rambling ....
Volumes have been written on how an air-conditioning system works. You will even hear people say that A/C systems are potentially overunity appliances.  What does it do? In short, it is a transfer of energy from one place to the other by manipulating the state of a refrigerant. Sounds pretty easy. I go from a hot vapor to a warm liquid in the condenser to a cold liquid/vapor mixture in the evaporator, ultimately ending up all vapor by the time it enters the compressor (because compressors can't pump liquid).
With a refrigerant system, a transfer of energy exists in two key places, the condenser, and the evaporator. If the condenser doesn't reject heat energy, then the evaporator will see a reduced capacity. In the condenser, we see a change of state and a large energy transfer. In the evaporator, we also see a change of state and a large energy transfer.
How ironic is it that the most violent boiler explosions are when water is heated, its boiling point raised, and suddenly exposed to lower atmospheric pressure causing the water to flash into steam.
So, this whole Change-of-State thing is pretty important and has been known in nature to be the source of massive energy transfer.
So question, what is a refrigerant? Well, a refrigerant is anything that can change its state. But more critical, a refrigerant must be able to absorb energy and reject energy.
Question, can a magnetic field absorb energy? Can it reject energy? If you answer yes to those questions, then you just found your refrigerant. Now we need to manipulate the field to do some work. In a refrigeration system, we need to control pressure, and this is the same culprit that causes massive boiler explosions. So we need to expand and compress a magnetic field. Compressing it condenses the energy of the manipulated field. Expanding it releases energy. So when you line up magnetic fields N-S|N-S|N-S that is expansion. Compression is N-S|S-N|N-S. Like the refrigeration system, these are the two key magnetic arrangments where energy is transferred.
All devices need three (3) coils, two are controlled and the middle one is driven. We need the driven coil because the Lenz field is compressed first then violently expanded. Depending on how hard you compress will govern how much OVERshoot you have in expansion.
Since everyone, in the past, had a good laugh when I spoke about a tire iron, I will go right to a better setup. A three-phase line reactor can be used, and you have three perfectly good coils all wound ready to go. You can also use a toroidal with three coils (always three). The guys in Brazil use a toroidal setup, and the Georgian (TK) uses line reactors. Actually, the first few Brazilian patents identified line reactors, and they can be seen in one of TK's videos.
Someone on this forum has a video where he placed magnets against a CRT monitor. The video shows an expanded and compressed magnetic field. However, he was applying the principles slightly differently, so he got some results but not all. Remember, it is the Lenz field we are compressing and then ultimately expanding.
aether22
Fascinating.
Sadly there seems little to glean from it.
Pressure might have had something to do with it, and apparently some electrical component...
He took the secret of his machine with him, and what little Google translate can make out seems to be of little use.
Clearly he achieved an extraordinary result though.
I have achieved rapid healing of people, not as rapid as "healing from a bullet wound in one hour" but a part deaf girl gained full hearing, and broken bones were apparently healed in real time, bruises lesson before your eyes.
On the plus side I am alive and not hiding anything, that is why no one cares.
Jeg
Quote from: aether22 on November 30, 2020, 03:35:23 AM
Hi aether22
Very interesting quote. Do you mind saying some things more on this? What do you use that is so beneficial for human's healing?
Thanks
aether22
forest
Magnetic field is the source of energy , is energy "per se" however in steady state flow (closed path). So it can be tapped, used , converted or even condensed from the powerful yet large (in area) source like Earth magnetic field.This is the truth explaining all free energy.
