Watch the governments Kill this componet again
Started by raburgeson, December 06, 2006, 01:10:35 AM
raburgeson
This has been invented in different forms several times and you get a chance to see history repeat itself, everyone sould be aware this is happening over and over for this and many other componets.
http://www
.cheniere.org/misc/chung.htm
Quit screwing around thinking it a conspiracy theory, it's a fact.
After they squash this, they will vote themselves a raise and party on your money.
pese
http://www.cheniere.org/misc/chung.htm
this way the link is working.
negative resistor are to make in many ways.
(@ low power applications)
cant?see that that is impossibel to make them bigger
Pese
P.S.
The "negistor , was my invention ! . Publisherd year before
Popular elektroniks in ELEKTUUR , Nederlands (as saw-tooth generator !)
raburgeson
I did that on purpose, sorry I thought there were to be no active links.
parallel , series many 5 ohm of them and run a car , this ones in it's infant stage. The one in 1923 was not. It will be squashed and swept under a rug quickly though won't it.
We concluded several years ago,
that the Chung resistor was only a partial differential
negative resistor, but not a real negative resistor.
So it worked only when an additional battery voltage
was applied, so it could not just amplify anything without power input !
So it could not be used to produce power...
raburgeson
http://www.rense.com/general/resistors.htm
http://www.gopetition.com/online/9814.html
(check out #2 on the list)
http://home.earthlink.net/~lenyr/zincosc.htm
It can be done with iron wire.
I think the one that's fully developed has been hidden long enough.
The idea is to produce them around 4 ohms like a car battery and hook them in a series parallel arangement. Well no the real idea is to keep you on a meter paying out the butt for energy. developement stopped in University at Buffalo Because the gov is standing on it.
Undeveloped yes, it's not to practical in it's present form.
You don't think the gov lets you see the good finished stuff do you.
And Most Importantly
http://www.intalek.com/Index/Projects/Research/NegativeResistorAndMore.htm
I have a nuclear phyicist in the family, mostly we fight, but he did answer one question of mine about free energy. He said, If you internally trick a curcuit into believing there is a potential difference current will flow. It took me years to figure out the statement was directly indicating negative resistors. That is the componet were the trick is accomplished. If it gives you heating problems it can either be cooled or more resistors can be added to lower the current per resistor also effectively cooling the unit. This circuit can also effect time and gravity, to what scale I don't know.
