New discovery suggest that permanent magnet motors might be possible
Started by Low-Q, September 26, 2018, 11:53:45 AM
Floor
@ telecom
Certain magnet interactions it sometimes seems, are almost made to boggle the mind.
It takes time and effort to sort them out.
Give it time.  Relax.
OK
Diagrams explanations
https://overunity.com/16954/magnets-motion-and-measurement/dlattach/attach/169582/
https://overunity.com/16954/magnets-motion-and-measurement/dlattach/attach/169588/
https://overunity.com/16954/magnets-motion-and-measurement/dlattach/attach/169174/
Watch / study the videos at          https://www.dailymotion.com/us     type in    seethisvid    in the search box.
         force = Mass     times    acceleration
                   but more fundamentally
         energy = force   times    displacement
         I will post more links when ever you want.   There are a lot more.
                   floor
telecom
I think I got a handle of the TD unit.
The way I see it, you limit RO going past 90, and it actually wants to go
to 180 ( to be parallel to SL).
Then you attach the weight to be at a certain angle when SL is far.
When SL get closer, it  pushes RO towards 90 by the repulsion field.
Please correct me if I'm wrong.
I don't mind to see more links though because its a very facsinating subject.
telecom
The key to Dr.Kozeka discovery is this chart.
It shows that at the distance of 5 mm  the separation force is 1/5 of
the original.
Quote from: telecom on March 08, 2019, 10:53:29 AM
the original.
Why 1/5 ? When "original" = no distance 1600 and by 5 mm 200 then 200/1600 = 1/8
https://patents.google.com/patent/US4345174A/en
                                      2 D cells electromagnet
Force,  at contact= no distance .      500 pounds
                                  1 mm distance  125 pounds
                                  2 mm distance.   31 pounds
                                  3 mm  distance.   7,8 pounds
F6FLT
the original.
The notion of force is irrelevant in matter of energy. Energy = Force x Displacement.
If you lift a 100 kg weight to a height of 0.1 m, at the end of a lever that has a ratio of 10 for the length of both arms, the force you will apply will only be 10 kg. Is it "free energy"? Of course not. The distance of movement of the lever arm on your side will be 1 m instead of 0.1 m.   100 x 0.1 = 10 x 1.
With magnets it's the same thing. The field gradient is not the same everywhere, so the lower force on one side will have to be applied over a longer distance, and the energy will be balanced in each zone.
Kozeka calculates forces but not work which is the only interesting concept, either because he is incompetent or because he is looking for investors for a scam (otherwise why?).
