Finsrud perpetual motion machine
Started by hartiberlin, April 02, 2005, 11:55:21 AM
0 Members and 117 Guests are viewing this topic.
freeenergyman2005
Where can I see a photo or video of this device? May I have permision to replicate it?
I've been working on Don Adsitt's magnetic ramping design for some time, but have not been able to get it to complete a cycle more than a few times before ot quits. :-\
hartiberlin
Freeenergyman,
youi can see pics and a movie here:
http://www.reidar-finsrud.com/sider/mobile/foto.html
Please report about your magnet ramp.
How many times did you get to loop it ?
Why not more ?
Do the magnets stick to the track ?
Many thanks.
Regards, Stefan.
freeenergyman2005
Stefan, the finsrud machine looks fairly complicated; very polished. Far more so than my lowly magnetic ramp motor. I drew from the concepts posted on Don Adsitt's site 'The very last page of the internet', which, incidently, was not accessible because the domain name had expired as of yesterday; I hope this isn't permanent. I also used the concepts from freeenergyforever.com which is Dennis Lee's site, on his 'Case for Free Energy' video about 9.5 minutes into the tape. According to Don Adsitt, Dennis Lee is a scammer. Nevertheless, I found the concept of magnetic ramping to be valid in both cases on both sites.
I used a pair of 360 degree helixes for my ramps, which I spaced apart in mirror image fashon. The ceramic block magnets are attached end to end, North facing up on the lower track and oppposite on the down facing track. The effect is that the magnetic field increases as an armature, which has four arms spaced at 90 degrees, rotates from the widest point to the most narrow point. Indeed the magnets, opposite poles facing the tracks, on top and bottom of the brass inertial mass are readily 'sucked' into the shaped magnetic field. The problem is that once the armature reaches the most narrow point of the stator it comes to rest after only a couple of rotations due to the intense attraction. By using the rollercoaster drop demonstrated by Adsitt, there is no abrupt end, and there is in fact a tapering off, though, alas, not an elimination, of the strong attraction associated with the end of the magnetic track. Having said that, I've only gotten four or five rotations after a slight nudge. Still I'm encouraged that this configuration might be optimized, despite the crude construction; there is significant friction loss, to be sure. To watch it, it obviously so much wants to work, yet it eventually, grudgingly, stops working.
Howard Malone
Kysmett
Is there any formula that dictates the strength of the attraction to the 'sticking' point, as a function of the strength of attraction in the gate.  I guess what I mean to ask was this: first, were the number of gates the same as, or an even factor/multiple of, the number of armatures?  if not, then how many armatures that are influenced to move does it take to overcome one that is influenced not to move.  I am thinking more and more lately of phi numbers....(regretably becoming more evident in my posting, for which I appologize).  I plan to build a simmilar apparatus in the next eight weeks, and I think that I will use eight arms and 13 gates, this will ensure that there will always be 7 bodies with a positive force for every one passing through the sticking point.
Most of the materials I do not have yet, so any advice or knowledge to the contrary of the above would be appreciated before I make the investment, modest though it might be.
Thanks
freeenergyman2005
Hello, Kysmett.
You're talking a little over my head, but I get the gist of your message. I used four armatures @ 90 degrees separature in my machine and, as I mentioned, had my ramps facing each other and arranged in mirror image. So, I guess, if I understand your meaning, I have one gate with the ramps being three inches apart at the gap, opening to five inches at the begining of the run. There is a one inch rise over 4' and 9 1/2', as my stator is 18" in diameter. It appears there isn't enough force of attraction through the run to force the armature through the gap without losing a little momentum as each armature passes. I have a total of 52 ceramic block magnets, purchased at Ace Hardware for $0.88 each, including eight in the armatures. Therefore, I have three inertial masses with positive force for the one passing through the gap, or gate.
I'm open to suggestions.
Howard
