The book is dedicated to self-propelled mechanical generating devices.
Started by rakarskiy, November 02, 2018, 11:56:37 AM
rakarskiy
lancaIV, our goals are the same! I have the same one of my tasks: Creating a self-propelled generating device up to 5 kW (kVA). Do you think that only one solution is possible? Much more. My task is to make all types of devices: mechanical, static (on magnets), and on the effect of resonance.
I have groundwork on all three points! The first mechanical is already in design. Approximately 2 kW to start development. Or, a small model for running the principle. (all this I post to the participants of the Project Source ")
As for your "MEG" s, do you think that it can be built on the principle of a transformer? You're wrong. Everything is much simpler and difficult at the same time.
Read the material: Russian Gromov, it was his work with the keys I tried, but he was also mistaken.
https://rakarskiy.io.ua/s1773029/bloking-generator_s_pitaniem_ot_postoyannyh_magnitov_gromova
The reason is that general information incorrectly explains the operation of the transformer. All were allowed on the wrong path, attributed it to Tesla. The whole world uses the transformer of another person.
QuoteDo not build illusions in power, size does matter.
For example, we take "philistine" indicators of 10 kW, output power, installation. We make simple calculations: for 1 hour of operation, the device produces 10 kW * hours; 24 hours - 240 kWh; in 30 days (24 hours each) it will be already 7200 kW * hours [7.2 MW * hours]! We look at our receipt for the payment of electricity for the calendar month and see how many kW * hours it takes to pay for the meter. Suppose you have an electric stove and hot water. The figure is about 800 kW * hour [0.8 MW * hour]. The question is what to do with the rest of the energy? You cannot store it in a two-room apartment on ... the tenth floor, otherwise you will need a huge battery the size of your apartment. At the same time every month will only stay. You can never sell it, world famous people have determined that you are a buyer, and you only have to pay!
We think further, but how much is needed?
We define average values: 800 kW * hours / 30 days = [26.7] 27 kW * hours per day - this is your average. 27 kWh / 24 hours = 1.125 kWh hours in ONE hour. This is an average figure. Naturally, consumption is uneven, and peak starts for the refrigerator engine and other devices are calculated for a total of 10 kW, but this is a fraction of a second. Then the simultaneous inclusion of devices and other things. The most interesting is that the main points of consumption you have a water heater and refrigerator. I see their power. The average power of the refrigerator ranges from 100 to 200 W / h (at rest), the maximum is 300 W / h (with the compressor running), that is, an average of about 250 W. Do not forget that the refrigerator is connected, working 24 hours a day. You can look at other electric indicators LINK. Directly connect the consumer to the generator, for example, 220 V / 50 Hz, single phase, you need to have enough power for peak starts, while ensuring that the voltage does not fall below 220 V AC. Such a mechanism was developed using a network inverter and buffer storage in the form of a battery of appropriate capacity. For stable operation, it is enough for us to have an output power of an autonomous generating device with permanent magnets with an indicator of 1.3-1.4 kW. According to his estimates, the battery capacity will be several times, and again, several times less than for a solar-powered device. How the home network on the 15th floor or in your house can look like is shown in the pictures:
FIGURE (SCHEME)
You can use your home network. It is enough to disconnect the circuit breaker from the network, and to turn on the socket circuit, the output of the convector is 220 V / 50 Hz DC / AC from the home network with free energy from the magnetic generator.
Yes, there is the/a difference between on-grid and off-grid energy consume behaviour and power logistic !
About peak-consume and regulation :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19950529&CC=ZA&NR=9407569B&KC=B#
https://patentauction.com/patent.php?nb=9456
For "autonom living the comparison between conventional and "oeko(logic/nomic) household :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.oeko-energie.de%2Fprodukte%2Fsolarstrom-photovoltaik%2Fsparsame-dc-verbraucher%2Findex.php
             18,65 KWh or 3,02 KWh
( I am missing in the listage the bread-backing-machine 800 W,  the Air2water generator 600 W,room heating in winter, .....)
Mr. Chalko,  mtbest " 0,8 KWh electricity per day ".   https://mtbest.net/energy_efficiency.html
+- 2 sqm solarcell( + reflector in Aussi winter)  and battery-set makes him autonom
For 4 billion earth habitants the "1 KWh electric power per day" is actually sufficient
                       ~ 125 W generator ( 9 hours work per day)  + 0,5- 1 KWh. battery-set
And how much do we ( physical and perfect organized really ?) need  ?
For the civilized europide family house a 3 KWh battery-set and "...?..." KW generator,  battery and electric consumer charging,  should be sufficient  !
"...?...": 3,2,1  KW. ?  24 hours day program and (K)Wp and (K)Wa measure and regulation,  peak/ average
Not an hundred Watt prototype,  but a thousand Watt prototype will become the
" Zero Energy Building" program  demonstrating object  !
BTW : some wants to explain " free energy " easy,  it is the permanent magnet : the source. !
https://patents.google.com/patent/FR2528257A1/fr" .... soit remplacee pour un electroaimant. "
So the permanent magnet can be -also- the source,  but which is -really the source. !( the Imris generator works also with/-out permanent magnet)
  Lenz current/ Ampere turns-pulse ratio
rakarskiy
Quote from: lancaIV on March 15, 2019, 08:01:53 AM
Wie Sie sehen, verstehen Sie und ich das wirklich. Was ist persönliche Energie? Zunächst gab es Gerüchte über einen Generator aus Deutschland, der ganz am Ende des Krieges aufgetaucht war, nur eine fantastische Geschichte. Ich beziehe mich immer auf die "Frage", um zu leugnen, dass dies unmöglich ist. Sie müssen auch "Unmöglichkeit" beweisen. Am Ende habe ich es gelernt. Dank seiner eigenen Forschung, Materialien Bedini und Cole. Und beim deutschen Elektro-U-Boot beträgt die Wahrscheinlichkeit ebenfalls 100%. All dies kann reproduziert werden, wenn sich die Deutschen für das Problem ihrer Geschichte interessieren. Ebenfalls in Russland erschien 1959 ein interessanter Elektromotor, der auf dem Auto installiert wurde, der Autor Stovbunenko. Sind die Behörden sofort verschlüsselt? Übrigens ist der gerippte Rotor eines Schrittmotors eine Erfindung von Stovbunenko.
https://sites.google.com/view/non-fuel-energy-generating/a-generator
        I.
A motor with electricity feedback,  kind roto-verter
http://geminielectricmotor.com/                                          now patent rights free
                                                               II.
https://patents.google.com/patent/US20040129308       which physical process and material. ?
A kind of "electric motor infeeder" :material. ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=JP&NR=2007028879A&KC=A#
the description translation :
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=JP&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=2007028879&OPS=ops.epo.org/3.2&SRCLANG=ja&TRGLANG=en
                                                  I.  + II.  combination
                                     Caution : inrush power demand phase ( f. e.  inrush current limiter)
                                      TARGET : electric net zero energy motor
                                     electric net zero energy motor application :
In India 50% from agrar fruit and vegetables are lost per year because they have not cooling chambers.
( Pakistan?  Africa?  South-/ Middle-America)
With low cost cooling devices like
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19890210&CC=FR&NR=2619201A1&KC=A1#
or
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=14&ND=3&adjacent=true&locale=en_EP&FT=D&date=19830601&CC=DE&NR=3143534A1&KC=A1#
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3143534&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
          Partial wrong translation : no-where " uranium" in the process or in the German original documents written
which they can produce in their own country  and get the " Net Zero Energy Cooling"- state.
Cooling for air humidity condensation and to get drink water is a second big priority.
And clearly fridge for medicine deposit.
In North-America the heat pumps/ chiller with electric net zero energy motor equipped.
E-bikes with net zero energy motors,.........
rakarskiy
 lancaIV, You probably want to surprise me. Do not try, I know all this for a long time. In Russia, for 15 years they have been producing and selling heat pumps of engineer Urpin. Our name is CAVITATIONAL MECHANICAL DEVICE.
Motors in America? The simple question is that then Ilon Musk on his car Tesla puts unprofitable asynchronous motor. Motor Joe Flynn in America and the motor Grigory Kornilov in Russia are closed for consumption by the bad guys.
Believe me, I have enough of their development.
I know their device. If they do not disclose, I will calculate it by engineering and analytical method.
This forum has information about Karll Luther's patent. Asymmetric - symmetric method for constructing a generator. In the park with the motor of the digit from his patent: 0.6 kW input, 7.2 kW output. You know the method I know. I came to him earlier than the information appeared. but Carl opened it much earlier than me. So it turns out that we invent something. what others have invented before. I want to say this in my book.
