A Treatise on the Magnetic Vector Potential and the Marinov Generator
Started by broli, November 13, 2018, 05:30:17 PM
Quote from: Smudge on November 26, 2018, 10:22:12 AM
I think you have to consider not only the change in the A field component along the semi-circles of wire around the magnets but also around the bends joining the two semi-circles.  As drift velocity is the same everywhere you find that the induction around those sharp bends completely nulls the overall induction.
Smudge
Smudge very good point indeed I have not considered that.
However if you consider this region and draw a small semi circle there and follow the change in A-Field around this path. From the charge's point of view the A-Field was at max and then starts decreasing as the charge moves along the path. When it exists it's at the A-Field's min (from its point of view). so A-field going from a max value to a min value is negative rate of change thus a positive E-field (E= MINUS dA/dt).
Or have I flopped somewhere?
EDIT: I guess I did flop. I was considering the wrong direction. Attached the correction. At Least the folded setup is indeed a no go as all the EMF gain is canceled out in that small u turn.
ayeaye
I made what i call wrapped magnet, on the figure below.
I took a hard drive magnet, wrapped it with insulating tape, then with aluminum foil, then again with insulating tape, to hold it tightly together.
Measured the current between both ends, it was zero. Measured the current through my body, holding the probes with both hands, the current was zero. Measured the current through my body and an aluminum foil in series, my body became a battery, the current was 0.07 uA. Measured the current through my body and the wrapped magnet in series, the current was 0.22 uA, almost stable.
Measured the current through the wrapped magnet and a big metal object in series, the current was zero. Made a circuit, a battery, a 5 k resistor, and wrapped magnet, the wrapped magnet generated no emf.
So how do you explain these results? My one guess is, my body is massive, and provides electrons, and the wrapped magnet really amplifies current. But this is only one guess. One may try with another objects that may supply electrons, such as ground.
My idea was, in that aluminum cylinder, the magnet creates vortex of electrons.
F6FLT
I've tried to measure a possible voltage difference between the two branches.
Each branch consists of 2 resistors of 120K in series, the two largest being placed in the area of the strongest vector potential gradient, the other two being used to balance the bridge.
The magnets are neodynium magnets from old SCSI hard disks.
The HP3468A multimeter allows stable measurements up to ten µV.
When the magnets are removed, or the poles are switched: no difference in voltage.
I have no explanation for this negative result, except that the effect, if any, is below 10µV in my configuration.
I took this picture before I realized that the magnets were not correctly positioned, but the same negative result after correction (90° rotation).
Hi F6FLT
Thanks for the contribution. The problem with the solid state setup is that you are pretty much relaying on the drift velocity of a material which for copper can be a few mm/s. At this rate the rate of change of the potential vector is very low. Compared to a conventional generator where the magnetic potential is flipping intensity 100 times per second in front of a coil that has N turns. This is quite a big difference. The challenge is to find ways to amplify this small effect, if it's possible we would be sucking energy directly from permanent magnets and see if they truly are permanent  8) .
There are three solutions to amplify this.
1. Use a material that has a much higher drift velocity than copper, For instance the semi conductor Indium Antimonide can have an electron mobility 10000x higher than copper. This is also why almost every Hall sensor uses a semi conductor sample because the very high electron mobility amplifies the lorentz force considerably. This option is pretty expensive as you need to order a wafer and perhaps also laser cut it.
2. Using multiple turns somehow. So far this proves impossible as can be seen any "return" causes the oppesite effect.
3. Use mechanical motion to move the electrons at high speeds. This method is as shown on the very first post of this thread. The advantage is that this is very easy and much cheaper to test. Both rotational and linear variants can be build very similar to Smudge's conveyor belt idea.
Here are some other key points after playing with the simulation
1. there can be a gap between the magnets, this does not affect the intensity of the induced E-field that much
2. Disc must have a hole in it to prevent eddy currents as these induced E field are the cause of eddy currents to begin with
3. Brush points do not need to touch the outermost sides, they can be at the location where the ring and magnet's edge "intersect" as this gives the max possible E field
