Self Powered Generators & Motors - Part 33
Started by seraphis, December 06, 2018, 05:04:03 PM
seraphis
Patent Number
AU18688/83
Title
GENERATOR-MOTOR COMBINATION
Abstract;
The specification discloses an alleged perpetua mobilia which includes an electric motor driving two permanent magnet generators mounted one at each end of the motor drive shaft.
The motor is initially energised by an external power source. When the generators produce outputs, the external power source is disconnected from the motor which is then energised by the generator outputs.
Description;
Drive motor - Standard 240 volts 1.9 amps AC  425 watts 50 cys. 3000 rpm, brush type or brushless.
Two multiple coil and magnet rotary generators are driven at each end of the drive motor as shown on the second sheet of drawings. (Fig 2)
Each generator as shown on sheet one of drawings has two sets of coils separated by twelve alternately faced permanent magnets (high flux density). (Figs Ia and Ib)
Inner coils I2 of at 400 windings each - 0.5 mm Cu. wire, are two series wound groups - producing 140v @ 1.2 amps AC.
Outer coils I2 of at 600 windings each - 0.5 mm Cu  wire, are three series wound groups - producing 140v @ 1.8 amps AC.
These two outputs are then rectified and connected in parallel, producing 140v @ 3.0 amps, then fed along with the other generator feed into two electrolytic condensers 1.7uF and 0.4uF
as shown in wiring diagram on sheet two of drawings. This procedure gives a combined DC output of 240v @ 6.0 amps, which on the prototype is converted to 50 cos. AC by means of a
brush commutator, which is on the drive shaft, the production motor will have quartz controlled cycle analyser.
The motor is initially started from an outside generator or source of energy, then switched to run independently, and when disconnected from this power source, will supply 240v AC @ 4.0 amps 50 cycles - approximately 960 watts.
Claims;
No. 1
The first electrical generator to operate with no outside source of power - using the natural radiation energy of permanent magnets and converting it into electrical energy
No. 2
The special coil and magnet arrangement reduces the drag caused by the compression factors of elementary particles enabling the kinetic moment of the magnetic
flywheel to easily turn and generate induced current in the coils.
Note:- The laws relating to this are observed in Quantum Mechanics.
No. 3
Multiple arrangements and size of the general concept will produce a progressive amount of energy.
Dated 28th August 1983
Carl J. LUTTMER
