Flynn / Lafonte slider - 800% OU possible
Started by norman6538, December 29, 2018, 07:33:23 PM
norman6538
Quote from: citfta on January 15, 2019, 06:41:29 AM
Can I ask a dumb question here?  Why was this thread started in a section of the forum that is supposed to be about alternative operating systems for a PC?  This thread has nothing to do with operating systems for a PC.
Good question. I could not find a way to start it in the right section..
Is there a way to change that?
Norman
norman6538
Quote from: norman6538 on December 30, 2018, 03:10:12 PM
Here is a 2 dimentional drawing that may help understand the basic movement.
Norman
I recently worked on this again but did not have much luck at increasing the power.
It seemed that not much of the mag attraction made it to the end of the metal so I gave that up.
Norman
norman6538
My work with the Lafonte cascaded has failed after 3 embodiments due to imprecision.
But I was able to demonstrate with a manual fixed setup that the stacking of magnets
from a cascaded device does turn the repel on and off at the other end of that rotor.
The video is here https://youtu.be/lBQ38F_WbUs
So the concept is valid but not  adequately embodied. I ordered some better bearings
to reduce the tolerance. So far I have had to make my own bearings out of long rods
for stability but that takes time.
Stay tuned.
Norman
Thaelin
  I tend to use inline skate bearings for mock ups for testing only. I can find a pair of skates at the local thrift for around $7 here. Not sure what your source would be. Still 16 of them for the price and you can always double them up for strength.
norman6538
Quote from: Thaelin on July 28, 2019, 10:15:20 AM
Thanks Thaelin. I have used them too and they are fine for 150 lbs of weight but
whit small forces the bearings are sticky and I use kerosene to clean and lubricate.
But for for the magnetic pull it require 2 like the farm gate and then a 45 degree
tightener...   When I get it bigger I'll probably go there but my preference is front
bicycle hubs that are fully adjustable and even they have to be thoroughly cleaned
and re oiled.
I am half done on my next version but I am tied up for 2 days so it will be Wed or Thurs
till I know how cascading works.
Norman
Norman
