Zero and Q device
Started by v8karlo, January 04, 2019, 11:18:12 PM
v8karlo
Quote from: vasik041 on January 05, 2019, 02:45:44 AM
Hi v8karlo,
Are you considering your devices as Free Energy devices ?
Regards,-V.
It does not look complicated to me.
Just try them.
v8karlo
Quote from: Hoppy on January 05, 2019, 04:58:52 AM
Hi V8carlo,
Why waste energy running a push-pull trafo, just to light a bulb that could be supplied direct from source?
And when you need AC?
Just plug it do DC source?
Bulb is output. If I draw transformer would you ask me the same question?
Is this circuit more efficient than standard half bridge converter, transformer?
It has the same characteristics as half bridge (output - 1/2 input voltage),
but this circuit returns energy to source and standard half bridge does not.
This is half bridge converter. (It's structure is mix of push pull and half bridge).
I use it in my circuits when I need AC for the past few years.
v8karlo
You all want 2 kW ready to use device with schematics.
It does not go that way!
It is other way around.
You find something small, and make it better and better, and develop it.
I share my experiments! If you don't like them. It's easy.
Just turn around and walk away!
v8karlo
Zero and Q circuits is AC input.Q is AC input and AC output.
Can you use Zero circuit on the output of J Half Bridge (or Q)?
Can you merge or stack this circuits together?
Can you stack 2 Q circuits?
Can you use 2 Zero devices with opposite phase input.
If you merge their output you have full cycle dc output with more extra light and heat.
Why use them separate?
Hoppy
Quote from: v8karlo on January 05, 2019, 08:04:20 AM
No, because you would not then have a need to be claiming anything special.
Have you measured energy ratios or are you just comparing voltage / current levels? I ask this because you make no mention of energy calculations in your 'book' and yet you talk in terms of improved energy efficiency.
