Zero and Q device
Started by v8karlo, January 04, 2019, 11:18:12 PM
Void
Quote from: v8karlo on January 11, 2019, 11:36:22 AM
OK, fair enough. You see, we didn't have to fight from the beginning. This is right way to talk.
And when you build it, it will be yours.
Hi v8karlo. I really am not following you. I really don't see how you interpret people
giving you feedback on your setups as 'people fighting with you'.
Anyway, I will see if I can find some time to analyze your zero device on a weekend
if someone else doesn't do it first. I do find it interesting that your light bulb 'L1'
doesn't light, or only lights quite dimly. It will be interesting to analyze to see what
is going on there. All the best...
Hoppy, do you see why light bulb L1 is not lighting?
v8karlo
Quote from: Void on January 11, 2019, 11:42:59 AM
HI v8karlo. I really am not following you. I really don't see how you interpret people
giving you feedback on your setups as 'people fighting with you".
doesn't light or only lights quite dimly. It will be interesting to analyze to see what
Look!
When someone just look at scheme and said: "It is not possible!"
1. He is completely idiot, and he is not here to help!
2. He is trying to provoke just for his own fun!
3. He does not know what he is doing, but with his accusations he looks very smart.
In reality he is scaring people off.
You can choose which one from that 3 makes me defend from such people.
Sorry, but this is true.
When you said you will try you started to act like scientist and others will see in you smart person.
I believe you are smart person, but you were scaring people away!
I don't like that. I like when everyone can post his Idea and not to be bullying by the "smart expert guys".
There are lots of young researchers here who are afraid to post. That's why.
And I didn't fight with everyone, just people who attacked before they even looked into the problem.
It was you, Hoopy and vasik041.
With everyone else I had more then normal conversations. You can read posts from beginning and you will see that.
Void
Quote from: v8karlo on January 11, 2019, 11:53:28 AM
Look!
3. He does not know what he is doing, but with his accusations he looks very smart. In reality he is scaring people off.
Hi v8karlo. You are doing it again. No one said "It is not possible!"
I believe Hoppy said to the effect that he thinks you are making some incorrect assumptions.
Does it not bother you at all that you keep making statements that are quite clearly false?
See my comment above where I pointed out several false statements from you.
People having a different perspective than you is no way at all 'people attacking you'. Unless someone
actually says that you are 'a fraud' and ' this is not possible', etc., then no one has said those things. ;)
I personally previously have actually made no specific comments at all on your 'zero device'.
I have pointed out my point of view that for a circuit to be 'free energy/overunity' it must be drawing
in excess energy from outside the setup somehow. That is hardly an 'attack' or anything like that. :)
v8karlo, sorry, but you just are not making any sense with your accusations of 'attacks' and the like.
People will always have different perspectives. That is a good thing. ;)
Quote from: v8karlo on January 11, 2019, 10:25:35 AM
Yes lancaIV.
I am counting that all of you are better engineers that I am.
That is why I made it open source, for you. For all of you.
Lots of good people and lots of brain power.
If you build it you will soon know about it more than I am.
I won't be needed any more at that point. And I am glad for that.
In my pdf I tried to explain principle and that is good point to start.
The law of serial connection can be used to get more.
The components are performing more than one task at same time.
Lighting a bulb and filling capacitor at the same time. 2 tasks.
And then using energy from capacitor once more trough bulb.
You are using energy twice.
And then cap CZero using law of serial connection to double grid voltage at same time,
filling caps to double voltage, so the power in caps is double. (175V so little less than double)
Without CZero on each cap will be only cca 90V, but there is 175V on each cap while it works.
But there are 3 caps, so they triple the current with double voltage in them.
So simple circuit, but every component does at right moment what it supposed to do and cooperate with others.
More than one task for every component.
So, yes.
Gricourt /Kovac resistor serie  :
https://worldwide.espacenet.com/publicationDetails/description?CC=FR&NR=2504768A2&KC=A2&FT=D&ND=3&date=19821029&DB=EPODOC&locale=en_EP#
                                                     calorimeteric experiment result :
                                                         5 Watt bulb 220 V : 4,3 cal/hour
                                                         5 Watt  bulb 110 V : 4,9 cal/hour
small indication, but demonstrates difference ! Impulse generator sourced ?
I  have been at the morning in OPorto and visited the Rua de Alegria, to look there : open/closed. ?
        https://www.gescontact.pt/campos-cardoso-3a68
Has been there between 2004- 2009 +/- 3 times a week ( 500 times +),  getting technician service by him :https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Envez&IN=&CPC=&IC=&Submit=Search
But closed. ( By their best time in the 70' ties 16 employees produced hundreds of transformators per day : it was the time when Televisor and Radios were repaired and not droped away)
So I visited several electro-/ repair shops to get the price of ni-chrome coil :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=JP&NR=2007028879A&KC=A#
1 mm diameter/ meter 1 Euro,  85-90 Euros/ Kg ( alibaba?  aliexpress?)
Yes,  indeed,  many improvement possibilities.
Have a nice Weekend
OCWL
v8karlo
Quote from: Void on January 11, 2019, 12:08:06 PM
I believe Hoppy said to the effect that he thinks your are making some incorrect assumptions.
First was impendance match, it can not work. (then I showed him same scheme without transformer)
Then it was bulb is to slow to react, it won't glow. (stupid) But he is expert, yes.
And more, and more....
Now I am asking you simple question?
Was it easier to build circuit with 5 components from trash and post one good and smart post.
You see, with all that numerous posts others saw what will happen to them if they have an Idea.
So it is better for them to shut up because expert is around.
I don't wanna talk about this any more.
You are not behave like that any more and our conversations become pretty normal.
Do you agree?
