Zero and Q device
Started by v8karlo, January 04, 2019, 11:18:12 PM
v8karlo
Quote from: Void on January 06, 2019, 01:14:26 PM
The energy dissipated in the load is 'consumed' energy. The current returning back to the source
through a load that is consuming energy from the power source will be at a reduced energy level.
This is because there is a voltage drop across the load.
Void,
In that case, what if the load has low resistance?
Actually, if the load is primary of Tesla coil (low turns)?Can you answer me, I need your opinion.
I have something on my mind.
So, my thought is:
If I use Tesla coil step up, my load is low resistance Tcoil primary.
So my primary is very low resistance.
Secondary is many turns.I step up to lets say 1000V.
Then I connect another Tesla coil on that one but step down,to retrieve amps back.
So I have step up Tcoil connected to step down Tcoil.
My question is:
Can I avoid losses what you talking about connecting two Tcoils that way.
Is that what Kapanadze is doing to avoid losses?
It just occurred to me when I read your post.
Tesla Patent: 2 x N ~ C1,C2                                                        L: ?
v8karlo
Quote from: lancaIV on January 06, 2019, 12:52:19 PM
v8karlo, some " Studentenfutter" + espacenet " Baltzar von Platen" electro motor
http://rexresearch.com/platen/platen.htm
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Baltzar+von+platen&IN=&CPC=&IC=&Submit=Search
Tesla,  later Otto von Traun ( co-op.  Hermann  Plauson) and from 2019 ten years back :
Project base
http://www.patent-de.com/20100114/DE102008032666A1.html
  some developments :https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Envez&IN=&CPC=&IC=&Submit=Search
I am not sure what are you pointing here?
You are connecting some dots, but...
Can you be more specific?
Aha ok, i didnt't see post before.
Are you pointing the same things but with coils?
AlienGrey
v8karlo :
  last question: yes ! But capacitive !
I think you are in the " L"- stage, but soon thinking about L+ NN - readytouse
   Too fast, learn to make errors and learn the effect from " different opinion":
   science " says" c, why not ccw ?
   electromagnetic regime truth or quantum regime truth !   Later:
   what differ DC from pulsed DC from AC and Polyphase AC experimental on a pony brake !
