What's a magnet/ gravity motor worth to you?? New way of thought.
Started by magnetman12003, January 10, 2019, 01:21:06 PM
magnetman12003
It also would be nice to have a geared track around the inside of the 4 inch pipe as well as a geared track around the internal rod magnet.  Why?  So the internal rod magnet does not slip sideways during repel movement which can easily happen even covered with a silicon pipe.
Does anyone know of a company that sells thin flexible plastic gear tracks other than using heavy automobile timing belts cut to length?
skywatcher
Quote from: magnetman12003 on February 07, 2019, 04:03:47 PM
This could be easily 3D-printed. But it will not work anyway...   ::)
magnetman12003
A long time ago Robert Calloway published  The Hamster Cage Magnetic Motor.  06/19/01
He described how to make it in detail.  Had it running for a short while until the rod magnets in repel hung up.  Possibly someone can come up with improvements on that design??   All that's needed is 4 rod magnets, a cylinder, center shaft, and some other non magnetic components.
Simple build but need much patience to get it going.
Click: Robert Calloway. Hamster Cage Magnetic Motor, Keelynet  and that should take you to his motor idea
That actually worked in repel for a short time.
Who might find all this interesting today?
eavogels
Quote from: magnetman12003 on February 09, 2019, 06:26:26 PM
Or follow this link:http://freeenergy2000.tripod.com/hamstercagerotor.htm[/color][/font]
magnetman12003
Click:  "MAGNET TRACK MOTOR"   A You Tube video.
it might take a little doing but it should work.  Bending iron rods is not easy. You might even use iron powder in some sort of very thick paste arranged as rods also. Stainless steel powder wont work.
