What's a magnet/ gravity motor worth to you?? New way of thought.
Started by magnetman12003, January 10, 2019, 01:21:06 PM
skywatcher
Maybe you could give a basic description of your motor wihthout revealing critical details ?
What kind of motion does it make ?  Does it rotate ?  Or more like a pendulum ?
Does it produce useful output power or does it only barely move ?
How big is it, and can it be scaled to give more power ?
magnetman12003
Continuous rotary motion. It depend solely on the weight inside the drum enclosure to generate power.
The floating weight inside the drum enclosure is the special part of the setup. It can't be seen normally unless the drum is taken apart and the insides shown.
My 10 inch model rotates but I have no way of telling how much power is put out presently.
Yes the model can easily be scaled up to where it might power a home if made correctly that is.
Non ferrous components are used in construction. Just 316 grade stainless steel, bronze bearings, wood or a plastic drum.  Many other materials can be used as long as they don't attract a magnet. Using all ceramic bearings for axle rotation would be a big plus as they are almost friction free. Right now I am using bronze bearings.
magnetman12003
I keep getting the network connection is lost.
Anyways this has never never
Been published before.
