A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
George1
Deep silence again? :) What happens here? No brave members in this forum, it's evident. :)
George1
Please look again at our post of March 05, 2021, 02:25:15 PM. A copy of this post is given below.
The text below can be found in many of our previous posts. Anyway let us repeat it again.
Have a look again at the book "Solved Problems in Physics", 2004, Volume 2, p. 876, solved problem 12.97. The author of this book is Prof. S. L. Srivastava (Ph.D.)
The same book can be found at the link https://books.google.bg/books?id=rrKFzLB9KQ8C&pg=PA876&lpg=PA876&dq=%22electrochemical+equivalent+of+hydrogen%22&source=bl&ots=tQ8PSMLet3&sig=ACfU3U2HOLB78XHl2o3q-JanapzSK-McJA&hl=bg&sa=X&ved=2ahUKEwjDpp2-zZXhAhWT5OAKHUfuBzUQ6AEwBHoECAkQAQ#v=onepage&q=%22electrochemical%20equivalent%20of%20hydrogen%22&f=false
For your convenience I am giving below the text of the problem and its solution.
12.97. In the electrolysis of sulphuric acid solution, 100 mg of hydrogen is liberated in a period of 20 minutes. The resistance of the electrolyte is 0.5 Ohm. Calculate the power consumed. Electrochemical equivalent of hydrogen is 1.044 x 10 -8 kg/C.
Solution: The power consumed is equal to 31.86 W.
Prof. S. L. Srivastava stops here his calculations.
(The related solution's set of equations is not given here in order to save time and space. This set of equations however can be found in the book or in the link above.)
WE DEVELOPED FURTHER PROF. SRIVASTAVA'S SOLVED PROBLEM IN A NON-STANDARD MANNER.
OUR FURTHER DEVELOPMENT OF PROF. SRIVASTAVA'S SOLVED PROBLEM LED TO COP > 1.
HERE IS THE ESSENCE OF OUR APPROACH.
1) Let us calculate the inlet energy, that is, inlet energy = (31.86 W) x (1200 s) = 38232 Ws = 38232 J.
2) Let us calculate the current I. The current I is given by I = (m)/(Z x t) = 7.9 A,
where
m = 0.0001kg of hydrogen
Z = electrochemical equivalent of hydrogen
t = 1200 s
3) The Joule's heat, generated in the process of electrolysis is given by
Q = I x I x R x t = (7.9 A) x (7.9 A) x (0.5 Ohm) x (1200 s) = 37446 J = outlet energy 1.
4) HHV of hydrogen is 142 000 000 J/kg. Therefore the heat H, generated by burning/exploding of 0.0001 kg of hydrogen, is given by
H = (142 000 000) x (0.0001) = 14200 J = outlet energy 2.
5) Therefore we can write down the equalities:
5A) outlet energy 1 + outlet energy 2 = 37446 J + 14200 J = 51646 J
5B) inlet energy = 38232 J.
6) Therefore COP is given by
COP = 51646 J/38232 J = 1.35 <=> COP = 1.35 <=> COP > 1.
IMPORTANT NOTE. Constant pure water and cooling agent supply could keep constant the electrolyte's temperature, heat exchange, mass and ohmic resistance, respectively. Besides 0.0001 kg of hydrogen (and the related amount of the already split pure water) is small enough and can be neglected as a factor influencing the electrolyte's temperature, mass and ohmic resisitance.
And one more interesting fact.
Literally the same solved problem can be found in an old Russian (still from the Soviet times) book "Сборник задач и вопросов по физике", 1986, p. 130, solved example problem 71. The authors of this book are Р. А. Гладкова and Н. И. Кутиловская. In the Russian version the data is a little different, that is, time is 25 minutes, the amount of generated hydrogen is 150 mg, Ohmic resisitance is 0.4 Ohm and the calculated power is 37 W.
Russians also stopped their calculations at 37 W.
Our further development of the Russian version led to COP = 1.37, that is, we have again COP > 1.
George1
1) We (our team) have created 11 (eleven) technology breakthroughs.
2) Two of the above mentioned 11 technology breakthroughs (entitled "IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?" and "A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1", respectively) are released freely here in this forum.
3) Our third technology breakthrough is an entirely new and revolutionary electric technology, which increases many times (twice as a minimum and more than 15 (fifteen) times as a maximum) the capacity of any standard electric battery.
4) As a next step we would like to sell our third technology breakthrough and/or to enter a certain kind of collaboration of mutual benefit for production of our third technology breakthrough on a large industrial scale.
https://www.ideaconnection.com/
Do there your offer :
Is this to understand like :
https://www.pveducation.org/pvcdrom/battery-characteristics/battery-capacity#:~:text=%22Battery%20capacity%22%20is%20a%20measure,battery%20under%20certain%20specified%20conditions.
        rated    Amp-h         + INVENTION      x 2 up to 15 times ?
Prediction example : 24 Volt x rated 85 Amp-h  + your/group  device/technique :
                              24 Volt x [ rated 85 Amp-h x (2-15)]
                                          battery lifetime in charge cycles a. without / b. with INVENTION ,tested ? Experience ?
EXCLUSIVITY ?    Patent applied ?! Utility model(l) application applied ?! Demonstration ready ?
Search machine : Venture Capital / forum / exposition  !
or international inventor fairs/expositions like :
https://translate.google.com/translate?sl=de&tl=en&u=https://www.iena.de/
https://inventions-geneva.ch/en/home/
George1
LET US PUSH FORWARD TOGETHER THE TECHNOLOGY PROGRESS!
4) Our third technology breakthrough is experimentally proved. Our third technology breakthrough has a working prototype
(accompanied by a detailed description of its principle of operation).
5) We would like either (a) to sell our third technology breakthrough only once or (b) to enter a suitable kind of collaboration of mutual benefit for production of our third technology breakthrough on a large industrial scale.
