A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
Material with highest melting point : Wolframite also called Tungsten  : 3422 ° C
Plasma torch flame = plasma jet melting temperature up to 7 x over Wolfram m.-p.: up to 40 000 °F (arc )
or 22500 ° K
Radio-active material decontamination possible !
Plastics vaporizing possible ! But is plastics to Syngas not more eco-logical/nomical ? Recycle process !
ramset
Yes tungsten
On plastic remediation....Any material consumed would add to combustion/available heat to make steam / power-plant ?
And yes the nuclear remediation of some material waste that Brown wrote about ( Canadian govt acknowledged?)
On plasma topic
Santilli  ( spelling) cogen plasma reactors made gas and power ? with plasma from municipal sewage
Magnagas??
I like ACCA's "LENR " heater
Would be sooo easy to prove the claim too
Member ION's "fixed loss to ambient" test protocol !
Have donor catalytic for experiment .... will hack out of car next few days .
Thanks Grandma
Sergh
The platinum catalyst increase the oxidation of hydrogen with oxygen.
This is cool and useful.
But.. to produce hydrogen from water a reverse catalyst is needed.
Another way.
It is a catalyst that enhances the separation of oxygen and hydrogen. Redox reactions. Reaction of hydrogen reduction from oxide.
The tension of chemical bonds using a catalyst.  A little more - and the ties will be broken.
What is this catalyst?
ramset
We have member here Johan -1955
He shared several years back that very small (teeny) lithium soap (dish soap in market (Spain)
Had lithium soap as part of ingredient
Well
This added to water drops per liter ?
Changed hydrogen bond separation strength in ICE applications from 2000C ( no catalyst)down to 1000C with itty bitty Lithium
Some here did water fuel tests with Johan advice 50 % water with fuel
Johan had dyno test 35KW motor at   70%++ water ... w emulsified catalyst as above
Ran better than straight fuel
So perhaps lithium could work in electrolysis ( is in soaps ...grease for bearings ( car) etc etc ?
Will add to the test of ACCA magnetvortex heater
Post 556 here
Edit
I see I did not pay attention
ACCA wrote "cordierite " not exhaust catalytic dust ( was another vid here .. now seems removed that had same looking heater as above but used car catalyst dust ( platinum etc
https://www.corning.com/worldwide/en/innovation/materials-science/ceramics/what-is-cordierite.html
Thanks Grandma
Sergh
It seems to have replicated one old patent on low-temperature thermal dissociation.
Thermal dissociation of water vapor by heating the catalyst substance in a vacuum chamber to 450 C.
The problem is that the vacuum must be so good, as the forvacuum pump is capable.
-98 .. -99 kPa = not work.
-100 kPa = work ( I'm sorry, but I can't measure the pressure more accurately with a mechanical vacuum gauge.)
Temperature lower 420 С = not work.
Сatalyst substance - ordinary zeolite. Zeolite-containing kitty litter performs slightly less well.
Hydrogen detector = MQ-8 module for Arduino, like this.
"Hydrogen detected" - more than 2.4 volts at the detector analog output, indicator LED is on.
But not usable yet:
High energy consumption for heating and a vacuum.
Probably another or modified  catalyst substance is needed, like this
