Newton's Magnets
Started by Floor, February 01, 2019, 02:25:37 PM
Floor
@ citfta
The shield magnet in the
https://www.dailymotion.com/video/x728wd9
video is configured like this attached PDF file
In my build I used  two magnets glued together edge to edge in a repulsion.
(I didn't have a single magnet broad enough).  This of course damaged
those two magnets over time.
           floor
Floor
Here is the PDF file again.....
So easy to miss.  It looks like the label for the png drawing.....
Floor
Quote from: citfta on August 09, 2019, 06:31:21 PM
  I do not remember seeing the first one before.
Carroll
I took down the original posting of it, because in the context in which I was thinking about
those interactions, I thought I would need to use two complimeting devices.  That idea did
not pan out.
    floor
citfta
I have done some rough testing using the idea from the magforshield pdf you posted.  Based on the results I have ordered some larger magnets to use as the shield magnet.  I ordered a couple of different thicknesses to see what effect that has on the  shielding ability.  I also now have another idea to try with one fixed magnet and the shield magnet and the other repelling magnet free to move when the shield magnet is removed.  I want to see how much more or less movement I get when only one magnet is allowed to move.  That build will also be based on the magforshield pdf.  Until I saw your video you reposted I did not realize  you could get that strong of repulsion with the magnets oriented that way.
Take care.
Carroll
Floor
@citfta
There is no "magforshield pdf "  uploaded by me.  Search for it and see for your self.
There is a MagforShield 1b.pdf.
Everyone please try to be more precise and clear in the communications.
                 floor
