Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
#Reply 210 :
From the Hildenbrand switch US7453341
to Sanshiro Ogino Hybrid-type magnet circuit US6369479 sheet 1 and 16 ( physical measurements) from 18
compareable with Flynn Parallel Path technology research results ( today www.qmpower.com )
to Ogino Sanshiro,Keiichiro Asaoka JP2003009558 Hybrid-type magnet circuit generator
color
Magnetic energy battery
Abstract
The magnetic energy battery of the present invention comprises a casing, a positive terminal and a negative terminal. The main body of the battery is a cylindrical permanent magnet (1) having two end planar surfaces which are magnetized such that a vortex magnetic field (2) is formed inside. The vortex magnetic field (2) is a circle form concentrically with the axis of the permanent magnet (1) and the direction of the magnetization is perpendicular to the axis of the permanent magnet (1). The battery can directly produce electrical power from magnetic energy and can be recharged by magnetization repeatedly.
https://patents.google.com/patent/WO1995012886A1/en
https://www.youtube.com/watch?v=wS92Mm4A8a0
In the Earth Engine Model 30 Demonstration, the upper and lower gyroscopes rotate in opposite directions.
If you infer the principle here,
https://www.youtube.com/watch?v=ATPet2N30Co
When the N pole of the magnet is attached outward, it rotates to the right or left,
If the S-pole of the magnet is attached outward, can it be considered to rotate left or right?
It appears that the gyroscope support is made of semi-magnetic aluminum, which is hardly affected by magnetism.
