Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 35 Guests are viewing this topic.
color
You need to experiment with four 500W bulbs to determine the degree of overheating of the MOSFET and push-pull circuit.
Otherwise, parts cannot be modified.
color
https://www.youtube.com/watch?v=wq6GZp97uPY
https://www.youtube.com/watch?v=biBfz0gmcnA
https://www.youtube.com/watch?v=dS_40HlW-6w
With someone who sells fake-generators
With the person who bought the fake-generator
https://www.youtube.com/watch?v=GiT0hPYSiss
There are people who prosecute fake-generators in depth.
I'm not talking about the sentiment of someone who bought a suspicious fake-generator.
It is possible that the seller, the buyer, and the accuser have directed.
Even some free generators are distorted by them.
https://www.youtube.com/watch?v=dS_40HlW-6w&t=41s
And now, I am going to do something with the circuit diagram that has been verified.
Some circuit diagrams have been further verified.
Dare to take out the old circuit and try to do something with a circuit that turns off in 10 minutes.
It would be nice to approach it with good intentions,
If it's bad intentions, the generator probably won't work.
But the generator works.
https://www.youtube.com/watch?v=nl9E8F1gOD0&t=23s
color
color
https://www.youtube.com/watch?v=Mx0Hx9mCo9E&t=0s
The owner of the video above appeared after six years and went into bullshit.
https://www.youtube.com/watch?v=ekMX5U2VtL0
Anton seems to have sensed something, but he's still wandering outside.
https://www.youtube.com/watch?v=AkScltKbwFY
Thanks to your information, Russia's status was cut with the Bedini generator. What do you think?
color
The difficulty is to wind the coil so that the inverter current induction field generated will not interfere with transistors or thyristors forming a 220 volt 50 hertz. here invent what you want want want shakes bifilar stavte intermediate trans.
The Full Text:
цитата автора:akula0083: "собирайте простой преобразователь 12-220, 24-220, 36-220..... ну кому как удобно или у кого какие радио детали есть. трансформатор поместите вовнутрь поля создаваемое индуктором от простой индукционной схемы. для весомого результата поле должно иметь силу которое может нагревать металлический предмет равный по размерам трансформатору преобразователя !То есть это наблюдение из собственного опыта берем кусок железа примерно того же размера как наш трансформатор на котором собран преобразователь и помещаем его в индуктор включаем индукционную так сказать печку и если металл нагреваеться достаточно быстро ну где-то за 120 секунд его уже становиться сложно держать в руках все будит работать Сложность в том чтобы намотать обмотки преобразователя так чтобы ток создаваемый индукционным полем не мешал работе транзисторов или тиристоров формирующих 220 вольт 50 герц. вот тут придумывайте как хотите хотите мотайте бифиляры хотите ставте промежуточный транс. Видео от сюда автор: akula0083: https://plus.google.com/u/0/103786798... видео от сюда http://video.yandex.ru/users/akula0083/ копии видео от сюда: http://www.youtube.com/watch?feature=... копии видео от сюда: http://www.youtube.com/watch?v=7C4yEA... канал с копиями видео:http://www.youtube.com/user/131313den... skype akula0083 ФОРУМ ОБСУЖДЕНИЯ УСТРОЙСТВА: http://realstrannik.ru/forum/39-kapan...
Let's remember what the Shark said about the theoretical moments of this device ;-)
it uses 2 generators 1 at a frequency of 100 with what is a kilohertz, the second for tens of hertz.
Coils with 2 generators are wound back.
the beginning and end of the pulses from the two generators coincide, which leads to mutual extinction of the field.
Mutual quenching of the field translates the transverse wave into a longitudinal wave (that is, the field of opposing coils does not disappear without a trace)
Such a change in the field occurs due to the impulse pumping of ferrite domains by a voltage without current; In resonance, the ferrite domains are temporarily rotated, returning to their place already carrying the current component
the total signal of all waves is removed on a removable coil and it is larger than at the input ...
Ref: realstrannik.ru
https://www.youtube.com/watch?v=ZmP_Y0Le6Wg
Acca(Wesley) :
https://overunity.com/14378/akula0083-30-watt-self-running-generator/840/
Someone correctly predicted at first,
Later it went to the Andromeda Nebula.
I read an article sometime back now about Avalanche Currents, I cant remember what or who it was on exactly now
https://overunity.com/14378/akula0083-30-watt-self-running-generator/msg399793/#msg399793
There is also mention of avalanches.
https://overunity.com/14378/akula0083-30-watt-self-running-generator/960/
And with the word that it was brought from a Russian cafe, the circuit diagram is released.
