Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 17 Guests are viewing this topic.
color
What is the effect of making two generators into one generator?
Akula and Ruslan's thoughts have faded a lot, but there are still people looking.
I learned a few years ago why Ruslan made a 2KW generator and then switched to 200W.
Usually, when you make a generator, it is the human mind to pursue higher performance.
Ruslan only makes small generators.
The generator generates tremendous heat.
If you don't catch the heat, the generator will stop working.
The influence of the weather is also great.
On rainy days, the operating time is long,
If dry weather persists, the generator operation time is short.
Therefore, it is difficult to operate the generator continuously without a special cooling device.
If you can't catch the generator's heat, you have to be satisfied with an experiment like artificial solar fusion power.
https://www.youtube.com/watch?v=PvmMs6mU0NU
color
https://www.youtube.com/watch?v=DIL-XKKu56s&t=4s
https://www.youtube.com/watch?v=TQ1f4LPimkU
Even if these people get farther away from the generator, humanity on Earth will someday become extinct.
And only a few of the last humans will freeze and die while wandering in space in spacecraft.
Isn't that a plausible prediction?  ;D ::)
color
Роман Акула для Илья Тесла, Владимира Лебедева и друзей на Глобальная Волна-The Global Wave
https://www.youtube.com/watch?v=atgV9OCpX5M
A few of us know how to operate resonance.
So they know who is right or wrong.
It's not something I can say at will.
Watch for reference.
color
EMJunkie:
EDIT: Lenz's Law, really this is not correct, technically, Lenz's Law is Negative Voltage, nothing to do with Current, but we typically view this Secondary Current aspect as Lenz's Law. Magnetic Drag, it is not properly termed or defined in Science! Back E.M.F is another area not properly defined. Again, E.M.F is measured in Units of Volts, and nothing to do with Current. There is a gaping hole in Electromagnetic Induction and no one has picked up on this gaping hole! What is termed as Parasitic Inductance is the path forward to Above Unity Energy Machines!
Voltage V = L di/dt and Current I = Voltage V / Resistance R:
The back electromotive force mainly generated in DC/AC motors is generated in the coil
The magnetization speed of VACOFLUX (cobalt iron) increases instantaneously.
Likewise,
When the two Yoke-transformer primary-coils collide at the peak, the secondary-coil formed by artificial-lightning also rises by the peak of the two primary-coils.
Here, when the primary-coil electrical signal switching disappears at the peak, a counter electromotive force is generated in the primary-coil.
Likewise, as back EMF occurs in the secondary-coil, the amount of current that a general coil cannot give is supplemented by the charge of the ground connected to the ground.
Here, the secondary-coil summons the amount of current that the lightning draws from the ground.
Therefore, there must be a Yoke-transformer in the resonance.
Resonance is difficult to occur without the help of ferrite.
So the push-pull circuit doesn't have to be complicated.
If two primary-coils collide unconditionally, the rest will follow by itself.
Tesla-kacher is not directly related to resonance because it only acts to activate the secondary coil and responds to the primary-coil resonance.
Only the way Tesla coils work is different.
By securing an optimized ground, the amount of current can be drawn infinitely.
The MOSFET's switching interval is the interval that can summon the optimized back EMF.
The spacing should not be too long or too short.
I can't measure because I don't have an oscilloscope.
So I get help from people around me.
Recall the kapanadze generator.
There is nothing complicated if you understand resonance alone.
It is because it is the simplest to generate resonance.
color
WhatIsIt:
Stay well, be healthy, regards, roses under your foots,
in this dare times.
Unfortunatelly, we live in today, not some future like you,
hundreds of light years away or hundreds of years in future,
In this dare time.
