Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Zeitmaschine :
Re: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
« Reply #22305 on: February 26, 2016, 08:20:40 PM »
Does a static electric field interact with a magnetic field?
Harry McLaughlin:
»Sure.
They interact, or better said, they combine to produce a flow of energy.«
Guntis:
»Static magnetics field or ionisation - called also as Dead Magnetic Field, but we can convert this field to meka a work«
Quote from: Hoppy on February 23, 2016, 09:49:18 AM
I agree that the blue coils do nothing apart from carrying current to the load.
I'm not even sure about that. Why routing the current through the blue coil? It is an unnecessary resistor. Routing the current straight through the plastic tube would also do the job.
I agree that the transformer is not capable of supplying the necessary current to the load, so it and its fancy coil are also eye candy because it could not possibly induce sufficient current into the blue coils, which we also agree do nothing.
Hence a new diagram to make it more clear. The phrase »it« translates to: Could it be possible that this green 3-phase transformer can generate a work and a flow of energy? If nothing else generates that flow of energy, then yes.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg475633/#msg475633
AlienGrey
Quote from: color on August 26, 2020, 04:44:14 AM
Zeitmaschine :
« Reply #17945 on: June 17, 2013, 09:38:10 PM »
Quote from: captainkt on June 17, 2013, 05:49:41 PM
When I tried to put connection between transformer and inverter the inverter blew up. Back to drawing board for me, so much for free energy I have spent thousands.
Because most likely the inverter is not an inverter. It's a converter, converting potential-free pulsed DC coming form a rectifier back to AC (by means of synchronized thyristors). The input side of the rectifier can be connected to an inverter (and car battery) like seen in 2004 and green box video, or it can be connected to an insulation transformer like in these presentations: 1, 2, 3
If the primary side of the transformer is connected in parallel to a capacitor (LC circuit) then a short impulse from a 9V battery will create also a sinusoidal wave which can be used to start the device if internally back-looped.
Now what could happen if we connect potential-free pulsed DC to ground via a large self-inductance (maybe in combination with a capacitance)? Could this large self-inductance be suitable to capture electrons from earth which then amplifies the output current?
Just speculating, don't want to blow up my equipment (yet). ;D
But at least nothing of this contradicts what can be seen in all the Kapanadze and Stepanov videos.
BTW: It's impossible to start a factory-made (off-the-shelf) inverter with a 9V battery. That means whenever TK starts his device with a 9V battery there is no inverter (don't think he soldered his own one), just a sinusoidal impulse. Furthermore that means there are three different types of TK devices: One type works with an inverter and a car battery, one with an insulation transformer from grid, and one with a LC circuit triggered by a 9V battery.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg363357/#msg363357
Ha, Ha, it might be 2x the frequency but you have cut the peak to poeak in half so it = same in as out
nothing changes.
AG
color
AlienGrey :
I don't know because I have not experimented,
It is also possible that the primary and secondary coils in the center of the three-phase transformer were used as Tesla-coils.
On the premise that it is possible.
color
Indians and Southeast Asians make easy generators very well.
The Chinese are naturally cloning ghosts.
Free-generator control is impossible unless Asia is completely extinct.
Are the only Asians who understand the resonance principle of the free freedom-generator?
Rumors have already spread to Europe, Africa and the Americas. 8) ;D ::)
The motor-free generator made by Bedini is bulky and difficult to handle, making it accessible to interested people,
The kappanadze generator type has the advantage that any electrical engineer who understands a small-transformer can easily access it.
It is now the capital market's job to prepare for the explosion of Free Electricity, not by suppressing the people who make Free Electricity.
The countries that suppress the Free Electricity will fall behind India, China and Southeast Asia.
Southeast Asia is a country consisting of tens of thousands of islands.
For them, the free generator is now a lifeline. ;D 8) ::)
color
