Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 23 Guests are viewing this topic.
color
This is just a parametric resonance posted as an example.
https://1.bp.blogspot.com/-7EBqr8aJipo/Xv6YxUElNDI/AAAAAAAAtpc/V4hlZCgMoaE0Csj52taceGAvDiqEjLpngCNcBGAsYHQ/s1600/Standing_wave_22.gif
When a back electromotive force occurs from a DC voltage, the positive electrons flowing through the wires according to Lenz's Law do not convert into negative, but flow in the reverse direction for a short moment.
The moment when two back EMFs in two TC4451s meet can be made equally with two diodes.
So, you just need to match the Tesla pulsation at the moment the two back EMFs meet.
So, if you control the pulsation of one TC4451 instead of two TC4451s, it is also the same for the two TC4451s.
So, the pulsation wavelength above is wrong.
Only the upper part is the plus back EMF pulsation.
There is no pulsation at the bottom of the Ruslan-generator's back electromotive force.
In this cafe, there are many people who pretend to be electric veterans while having novice knowledge about electricity.
Biography beginners refer to those who only know knowledge.
I am one of these. ;D
color
Back EMF simply repeats forward and backward.
However, the excess electric resonance that occurs in the yoke-transformer is all about replenishing the Tesla charge at the ground in proportion to the charge at the ground as much as the high unbalanced charge generated by the resonance.
I'm a beginner in biography, and I'm wrong? ;D ;D
color
You talk,
Will I listen?
It is said that the placenta's ship goes to the mountain when talking alone. ;D ;D ;D ;D
color
lost_bro : [ 1091 ]
Re: Kapanadze Cousin-DALLY FREE ENERGY
Reply #16358 on: December 20, 2016, 03:53:41 am »
Good day All;
Found this information, check attachments.
These are from videos posted by Andrian Dniester on his website.
This is another of his videos just posted 4 days ago; https://www.youtube.com/watch?v=0Sg9UPTZ9Vc
This shows the interaction of the Current XFRMR and Voltage at the Inductor at different resolutions, this is something that neither Akula nor Ruslan ever showed.
You can see that he has Resonance by the Yellow trace (Dancing Sine Wave that Ruslan talked about).
And the Double Current Spike (blue trace) which seems to mimic the pulse sequence from the Karcher output (voltage pulsing Current)
Qoute: Andrian Dniester: "Schematic is not so much of a secret............ tuning of coils is the secret....."
and:
"I was trying the diode and it works much better because half the period was filtered out."
take care, peace
lost_bro
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg497411/#msg497411
Read more of the members' discussions following.
If Andrian Gusca used two diodes in the yoke-transformer primary coil, is the waveform from the secondary coil pulsating like a fish or a pot?
It seems to me that Tesla is combined with a typical capacitor charge and discharge waveform.
Амплитудная модуляция 1
https://www.youtube.com/watch?reload=9&v=JHipZaGwd48
Andrian's yoke-transformer is a ring coil.
It's all about a safe supply of voltage, a little amplification of current, inductance and circuit protection.
My prediction is that the AC-live power from the single-wire ground is separated using two diodes, passed through the yoke-ring coil, and then goes straight to the light.
Tesla is an ornament.
color
My understanding is that  when bifilar  coil that has two ends connected together ,  at the end of grenade " kielbasa" winding and is  covering only part of that grenade than  the rest of non balanced  winding  marks an  area   in space where  inductive  reactance active.
Only in that marked space inductive reactance along with magnetic field  are able to induce current in neighboring windings    as far as resonance- even in non parasite  resistors  winded  bifilar inductive reactance is not totally eliminated .
So it does have traditional  resonance frequency  where both capacitive and inductive reactances are cancelled. Another words   in series resonance the only present component of impedance is physical resistance of the  conductor- at that particular resonant frequency only.
What is interesting  is- the beginning and ending of  impulse in the form of  square  or rectangular,  If it was top  of the impulse we are talking about  than it  IS IMPORTANT TO US  TO KNOW THAT IT DOES HAVE MANY SINUSOIDAL COMPONENTS  OF DIFFERENT FREQUENCIES TO MAKE THIS SHAPE BUILD . ?The top is for us  or looks for us  like DC the leading edge and falling edge  is pure  AC . The same will be with  DC from battery that is interrupted . You will have AC in the same places of that impulse.
One or more of transversial components of  AC  will possibly work for us with  that self resonant( parasitic) frequency.
So than we will make two resonances at the beginning  and at the end of square impulse .
By regulating  rise and falling  edge time we are regulating the very parameters of that two impulses.
So think of it in bifilar like :
-the start impulse,
- than when the voltage is at max -there is nothing  no inductance no magnetic field but capacitive reactance  is still present(hmm I need to  think about it)
-and than falling edge impulse.
Now if bifilar winding is done from two layers of thick foil with insulation in between  than capacitive reactive component is magnified  by that the voltage  increases dramatically.
One of thoughts I just have is  an experiment where two layers of foil are  connected together at one end and than connected in series with  wire (coil) that is not bifilar .
That not balanced wire will act like coil to induce current in that neighboring coil in area or region of that coil.
The first very "capacitive bifilar" will only make two impulses per period and wire coil will make constant  transversial influence on other coil.
And this is what Tariel Kapanadze was trying to achieve using spark gap -when  variety of frequencies are present in spectrum from very low to over 1GHz
He was not worry where it will trigger with one of its components a desired impulse activity in the  grenade .
All the time there was  always one  present. and ready for him to interact.
Later on he switched spark gap to spark generator from gas  heating stove. The HV impulses  have been ready for him already in train of impulses generated by that module. If you take one and put it on spectrum analyzer you will see  noise signal  made  of many frequencies.
TK problem with spark gap was that  it was not steady. The maximum  of that spectrum was drifting and from time to time  spark gap was in need to be adjusted.
The coaxial cable used in device that was presented to me  was used like shield connected to inner  wire at the end of that coaxial coil and the surface  of shield with inner wire created  also capacitor.
At the certain point there was one wire that was injected to that coil  and I assume there was also few punches in that coax to make  from it leaky feeder that increases number of harmonics or parasite components .So the bottom line is that  wide spectrum of sinusoidal impurities is a must.
We refer to these words as '공염불(a fair but empty phrase, cant)'.
Words useless nowhere.
