Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 277 Guests are viewing this topic.
color
made this didn't get any where with it the two frequency don't lock in phase.
I don't know exactly what this means.
To understand, you need to check it with a picture or video.
I am blind in one eye. ;D ;D
If 4.7kΩ-resistance is attached, it is likely A rather than mA,
As long as Ruslan cheats many people, it's hard to believe all of his words.
It is common to believe what you see. ::)
color
Jeg: [p1097]
Re: Kapanadze Cousin-DALLY FREE ENERGY
Reply #16447 on: January 01, 2017, 12:58:20 PM »
Quote from: endlessoceans on January 01, 2017, 12:09:02 AM
Regarding your question about the thick wire.
All the principles of how this operates are set out in text books. You will require thick wire AND thin wire. Each serves their purpose.
Indeed great posts ocean! But even greater, is when someone once a while offers a direction to research for.
Mac farland Cook used thin and thick wire combinations for his oscillators. I recently used thin and thick wires combination for increasing the interaction between two discharging coils. But regarding oscillators, I know how difficult it is to synchronize your coils correctly. I attach a video which was my starter to this oscillating wonderful world. I hope we will read more for your research soon. Keep it up and many thanks.
Radu Motisan's self resonant oscillator modified for 50MHz
https://www.youtube.com/watch?v=9XinprHC4sw
On January 1, 2017
Jeg reminded me of something.
It's a meaningful video, but those who don't understand it don't.
color
AlienGrey: [p1097]
Reply #16448 on: January 01, 2017, 05:07:23 PM »
So ocean is saying you can't get more out than with a man made device than in,''RUBBISH''! for a start Nelson has already proved that you can and has made a profesin of the skill, and Tesla also said an iron crore based device is the path to look at, if your too lazy to experiment and just pick flies then you have no experience in what your talking about on on advising others and any one following that advice could be missing an opportunity! I rest my case. Dude! ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Ello, Ello, Ello, looks like Richards back, I bet Wesley will be pleased !!! :o :o :o :o :o :o 8) 8) 8) :P :-[ :-* :'(
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg497878/#msg497878
Is actually an inflection point,
The runners who were making their own generators didn't stop. ;D
color
Jeg
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #16472 on: January 03, 2017, 12:27:51 PM »
Quote from: verpies on January 03, 2017, 11:27:19 AM
Hi guys.
The problem for me is that we are right in the middle of the process of moving from what we already know and use,  to impulse technology. Some can say that Impulse tech has many secrets. But what we usually call a secret, actually is an unexplored place that we never been before, and by studying it it's not a 'secret' or magic anymore. KML wires also use the same 90 degree tech to enhance the output.
Coax cable except of its excellent capacity/coupling between the two conductors also provides an imbalance between the outer and inner conductor due to its concentric geometry. This imbalance is necessary in to what we are trying. See leyden jar caps.
AlienGrey
« Reply #16473 on: January 03, 2017, 01:25:35 PM »
before you all boldly go where no man has gone before (as if that were true) why don't you do your home work ? hmm!
Have a look at your device and ask your self is it in harmony with the collective ? if you think it's a joke, then your wasting your time here, make sure all your wingdings are in harmony. and use Maths to check everything and base your device on the earths resonance.
I know i'm wasting my time telling you all, but check everything including spacing.
So suppose the katcher is related to a 40m grenade coil how would you work out the katcher winding length and considering if you used a spacing between wingdings what would it be in order to capture all the harmonics ?
If our katcher is consider our primary what would our spacing and winding length be for optimum gain be for such a device ?
So before you bin it all have you done this or just built a visual none working replica of some one else's device just using guess work ??
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg497976/#msg497976
color
;D ;D ;D it's like Morecombe and Wise on here, two separate threads, and one looking for how the device works (particle physics) and an other of a what if thing! Hello but I have not seen a single explanation into how any of it works or one that does work, So any chance we can center on reality in here ?  ;D ;D ;D ;D
Look guys when they talk about resonance THEY ACTUALLY MEAN RESONANCE, THE Egyptians had this philosophy AS ABOVE SO BELOW they were NOT kidding !!
A|G
나는 고대 이집트학의 (자칭)박사입니다. ;D ::)
