Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
это интересно Сергей.
https://www.youtube.com/watch?v=unywsWcgipo
хрень
https://www.youtube.com/watch?v=teq8y0o1-q0
https://www.youtube.com/watch?v=5iPfe-5ESgg
Format Kostyana found something interesting. ;D
Effect of ferrite or ferrite-core on inductor-coil (title) ;D ::)
color
cheappower2012 [1182p]
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #17727 on: August 15, 2017, 12:28:52 PM »
Forest the spark has nothing to do with the operation
of the device.Tariel uses the argument that its
a Tesla invention to send people on a wild goose chase.
If it has Sparks and coils its a Tesla invention,how silly.
Tesla is considered by many here as a god,very sickening,
there is no proof he invented free energy of anything.
Don't you have con men in your country?
There are a lot of Kapanadze devices that don't use spark gaps
however all use coils,one uses 3 coils on a wooden spindle
one for each phase,its a 3 phase device.All devices operate at 50 HZ
none at higher frequencies.Tariel makes hes living making devices
a person pays for a device to test,not to make ,sell or own,most likely the devices are
simple and would get stolen very quickly and copied,
there are a lot of thieves and pirates in the world
or you might prefer the term opportunists.You can't patent the device
,make it or sell it,your not going to get a million dollars,your going to get nothing.
Tariel recognizes this,so he sells a false dream to an investor,to get money from him.
I believe the tariel kapanadze devices are real,may not be totally perfected,the ones made by other people are fake and don't really work.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg509518/#msg509518
When I was in the old tpu thread,the same thing happened, people
listened to the inventor say something and ran with it.I can't get this to build the device,conclusion it must
be important,this happens in this thread,your being tricked by Kapandaze.In the tpu thread it was the inventor
wants you to build hes device
and would never lie to you,stupidity reined in that thread.In this thread, its a Tesla invention,
it operates at high frequency,the coil construction  is the secret.
Here is another of Kapanadze's devices,the ground wire can not be  two wires Hoppy,
the fan that he uses operates at 220vac ,50 Hz so the output has to be 220 vac, 50hz.
At the max power it draws 14.8 amps times 220v=3,256 watts,the guy takes a current reading.
The ground in my opinion does not do anything, simply a trick to convince you its related to Tesla stuff.
Pay close attention to the two spark plugs no arc coming from them,whats a Tesla with no arc,LOL ;D.
As far as I can tell there is no hidden wire,so the next trick would be hidden batteries
and a dc to 220v inverter,the size of the inverter rules this out,max power 3,256 watts
for a 12 volt dc battery,the current draw would be 271 amps,I'm assuming a 100% conversion rate
for arguments sake,in reality,the current would be much higher.There is no room in the box for a large inverter or
battery that can deliver this amount of current.In my opinion the coil is a very important
part of the device,this is where the current is generated,notice two wires are tied together on the output white coil,in parallel to increase current.My opinion is the current is not generated in an ordinary way but in a completely different manner,this is why its very hard to figure out,you have to look at all the various devices Kapandaze has made. Check it out and discuss it,skeptics,how did he do it.
https://www.youtube.com/watch?v=EH9VhcDZYKg
There are members who know that Tesla has nothing to do with ferrite-transformer resonance, but it is a lot of regret to remain silent.
color
cheappower2012 : [1183p]
« Reply #17744 on: August 16, 2017, 08:45:39 AM »
Hi Hoppy
The question I'm sure you have thought of is how did Tariel came up with
this device why not someone in the UK,USA,in the rest of Europe
or other parts of the world.What does Georgia have that the other places
don't have.We know that Tariel is a tinker,hes very smart,not an electronics person
he will do things a normal electronics person will not do,hes a very tricky
person,has no trouble twisting the truth.I pondered this question for a long time until the 2012 device
came along.It turns out the green Russian transformer is unique,to the soviet states,was made from
1970's to late 1980's,a lot were sold for surplus.Almost all transformers were constructed
like this.This type would be one Tariel could get easily,you would never see this in the
USA or Europe.I believe its part of the  operation of hes devices,its the part,he winds
himself,the unknown part.This type of transformer could be though of as two almost toroids back to back.
The coils are dipped in a resin green substance,fairly easy to take apart.I located a company in the USA
that sells the same type of cores.Remember when the 2012 device was made Tariel was very sick,he didn't wind
the main device but used a transformer from a Russian IBM clone power supply.Normally he hides
the transformer,the transformer is run in a certain way this causes heat,this is why he didn't want
IR imaging used,it would point to the transformer.There is a circuit that the transformer in the 2012
device uses,there are two parts that generate current one is used to power the load,the other is used to create
the current needed to create the condition,the feed back to loop the device.Its very hard to believe this part,its speculation on my
part,its a guess based on what I see.A coil is in all of hes devices and are a main part of the device.
The current is generated in the coil,how the coil is wound plays no part in its operation,the current
is not produced by an induction mechanism,its the length that's important.There exist for speculation
purposes an unknown energy source not recognized as an energy source,the transformer,when connect correctly
interacts with the unknown energy source,producing waves they are not ordinary waves,but have the ability
to create a push,different from a photon.the energy for the waves comes from the unknown energy source,The cross section is very small,
when they pass thru the wire coil,  they strike
electrons,this gives the electrons a push,it transfers the energy of the wave to the electron,as the waves travel thru the wire they hit more electrons,the result is an increase in the current not the voltage.
In the 2012 device there was a funny looking coil with  enamel insulated wire ,its purpose is to amplify the current to help power
the device .The tpu uses a similar application the difference
is the toroid is pulsed at a low frequency,the coil it uses is a bifular coil,most of the energy is lost as heat in the
primary winding,the secondary of the bifular coil is connected to a rectifier and capacitor to transfer the energy of the pulses
to the load.The bifular coil gets very hot quickly.The current is generated the same,any way that's my speculation.
This is why its very hard to figure out the Kapanadze device,because your dealing with
unknown principles and an unknown energy source.If you approach it using conventional electronics you would believe its likely a fake.
If you use this model of waves generated,then passing thru a coil
then you,can see that the 2004 device has a simple wave generator in the can,the coil,creates the current.
In one device he creates the waves in a box, Its set up as 3 phase,then uses 3 coils one for each phase
to amplify the current.The coils are not special but simple rolls of wire.
The first step is get a theory of some sort and see if it fits.Everybody suspects that the device is very simple
which is why Tariel guards the information closely,however everybody wants it to be Tesla related
and fall under conventional electronics,that's a big mistake.
I'm interested in the Nelson Rocha
device not sure if its real or fake,however the one using the toroid could be real,it operates
at 5k Hz and is started by a 9 volt battery it seems to fit my speculation and there should be enough clues
for replication.Nelson is also a tricky guy not sure of hes intent.A few of hes devices appear to be overunity
they look fairly complete,why is the company he works for not going into production,a very strange thing,very fishy.
If you apply this wave generator,connected to coil generated current theory to the 2012 device.The transformer can not source
the high current needed by the heater load,2kw.The waves exit the terminal that connects to the large coil that connects to the heater load.The waves do not need a thick wire to travel thru it
a very thin wire would work fine,as the waves inter the large coil
they begin to strike electrons,the current builds up along the wire
coil,until it reaches the heater.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg509581/#msg509581
color
I think Kappanadze didn't use a silicon-steel transformer.
Apart from the energy lost by Joule thief's heat, a silicon-steel transformer is not suitable for resonance.
It is very likely that Kappanadze also used a ferrite-based transformer.
color
In the presence of a secondary amplification-transformer, the resonant-transformer need not be large.
This was proved by Basmus.
