Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 39 Guests are viewing this topic.
color
DC generators can also create frequencies like AC generators.
It is possible with rectifier carbon.
It is shorter than the alternator frequency interval.
Khz is also possible without a transistor if you get enough torque.
https://1.bp.blogspot.com/-KardVMLbojQ/X2pYmID1-vI/AAAAAAAAvOU/4tYeSjFwvmg0WcK04cyPvRMc8_VD6jQEACNcBGAsYHQ/s16000/AC7.gif
https://1.bp.blogspot.com/-NaCMgIUmrgk/X2pYo7qEuvI/AAAAAAAAvOY/QJqPlHOEdTMMn-uVK4BywmzHifyarZy0QCNcBGAsYHQ/s16000/AC11.gif
https://1.bp.blogspot.com/-IsuQWIwqDds/X2pYqfYUUoI/AAAAAAAAvOc/cq_99EZwoj4GKMkIWFhiBP1tb0FQCHMxQCNcBGAsYHQ/s16000/AC10.gif
What happens when the two positive power sources of the DC generator act as the primary coil of the transformer and the Tesla combines in the secondary coil?
It can be assumed that Nikola Tesla and Henry Moray made enough free generators without the help of other special electrical parts.
But,
The theory and practice are different.
AlienGrey
Quote from: color on September 22, 2020, 12:43:34 PM
AlienGrey
Are Ruslan and my dad the modern-day Moses performing miracles?
You need to check the schematic you have made.
How long ago was that ?? It's in bits now and that controller has been modified
with the Katcher controller on top, it's still useless though! it took me a while to find it.
And would that be Thoth Moses or Elohim Moses ?
color
Jeg
I never recorded all of my experiments with Ruslan. When I found a dead end, i turned my focus to smaller devices with which I can use my oscilloscope without worries.
You know there are many issues that has to be considered individually. One of them is ''grounding''. We have two references. One is the system's ground, and the other is the earth ground.
How you deal with this? At the attached image does anyone know what this output line filter looks like? What ruslan uses there?
나는 Ruslan과의 모든 실험을 기록하지 않았습니다. 막 다른 골목을 찾았을 때 나는 걱정없이 오실로스코프를 사용할 수있는 더 작은 장치에 집중했습니다.
개별적으로 고려해야 할 많은 문제가 있음을 알고 있습니다. 그중 하나는``접지 ''입니다. 두 가지 참조가 있습니다. 하나는 시스템의 접지이고 다른 하나는 접지입니다.
이것을 어떻게 처리합니까? 첨부 된 이미지에서이 출력 라인 필터가 어떻게 생겼는지 아는 사람이 있습니까? ruslan은 거기에서 무엇을 사용합니까?
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg533170/#msg533170
I understand it as an extension of the problems my dad raised before.
The grounding of all systems is separate from the grounding of the ground.
The combination of the system ground and earth ground inevitably results in a short circuit in the generator system.
The generator does not work.
예전에 나의 아빠가 제기했던 문제의 연장선으로 이해한다.
모든 시스템의 접지는 땅의 접지와 구분된다.
시스템 접지와 땅의 접지가 결합되면 발전기 시스템에서 필연적으로 합선이 일어난다.
발전기가 작동하지 않는다.
color
AlienGrey
It's Djed-Moses.
https://www.youtube.com/watch?v=s0C-49K7BOs
It was an experiment by my dad in the fall of 2016 while sharing opinions with Russian-cafe users.
https://www.youtube.com/watch?v=LGvNv2EXKkU&t=59s
AlienGrey
Resonance is just a winding a katcher or grenade has to be like the girly cartoon clip you posted one turn too much
and it's out of sync or resonance also the length of the wire spread also has to be node to node for that frequency you select
just like Amateur radio or it's out of tune imagine a screw thread, but I'm just guessing. But when I was a kid an
old retired guy showed me his transmitter he could produce excess power when he was tuning up. So it must be possible.
He moved to his retirement home by the sea after that never saw him after that.
But he raised those points.
