Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 28 Guests are viewing this topic.
color
color
Any kind of Tesla will work.
However, it must cooperate with the transformer resonance.
The BTG white light that Ruslan recently posted, my dad developed it five years ago.
easy.
Ох уж эти стоячие Теслы ..... 2 кВт или 20 Вт ?
https://www.youtube.com/watch?v=IYQ9UJ-pgz8
color
Installing a Wood Stove and Oak Flooring in an Off-Grid Tiny Log Workshop
https://www.youtube.com/watch?v=Kk5F_gMfpNo
I think your Off-Grid log cabin needs a free-generator. ;D ;D
color
https://www.youtube.com/watch?v=hDXEC6GeGA0
https://www.youtube.com/watch?v=C0R4Pinl5rE
don't know why those involved in the Lithuanian OU experiment give value to their own strange experiment.
https://www.youtube.com/watch?v=Mn8TLBsR3r0
The above experiment is simple,
https://en.wikipedia.org/wiki/Townsend_discharge
It is just an experiment on the avalanche effect known as Townsend discharge.
Townsend discharge appears in an experiment using spark gaps.
It's true that a high voltage Tesla produces an avalanche effect,
Townsend discharge is not related to the Kappanadze/Acura/Ruslan generator principle.
It does not mean that it is completely irrelevant, but that it has nothing to do with Townsend discharge and the principle of development.
https://www.youtube.com/watch?v=5nxKqfkkndw
The spark gap shown in the video above is not a spark gap for Townsend discharge, but a basic spark gap for Tesla high voltage to work.
In order to activate the earth-ground with a high voltage like lightning, a transformer of a flyback structure must basically have a spark gap.
This is not a spark gap that causes an avalanche effect, it is simply a spark gap for high voltages.
https://www.youtube.com/watch?v=BQuOBBj8D_o&t=331s
Charge unbalanced lightning has a high unbalanced amperage by itself.
Charge imbalanced lightning produces a more transcendentally balanced amperage only when negative and positive charges meet.
It is correct to say that this is a short circuit-spark.
That's why the Kappanadze/Acura/Ruslan generator principle is called the lightning-discharge principle.
so,
The Lithuanian OU experiment is independent of the Kappanadze/Acura/Ruslan generator principle.
The Kacher schematic below is a Tesla that is not directly related to Townsend discharge.
The Kacher role is all about activating the earth-ground and drawing electric charges into the generator.
I would like to ask the Lithuanian OU experimenters.
https://www.youtube.com/watch?v=u3LhwQI6ABw
Do you think my dad's experiment in the video above is Townsend discharge?
color
AlienGrey
The below Romanscope experiment using a microwave transformer belongs to the single-wire transmission technology.
It is not strictly a single wire transmission technology.
MrRomancorp
https://www.youtube.com/watch?v=ET7CrFDs6fY&t=0s
This is an experiment in which Romankov confidently evaluated the Kapanadze-generator.
Similar to Wesley's Lithuanian OU.
https://www.youtube.com/watch?v=nmmzKKNULVo
юра сам
там где он показывает направление магнитных потоков на 5.10 минуте. от либо говорит ложь либо не знает. магнитный поток наведенный проводником не может вращаться не вокруг этого проводника. а он показывает что проводник в окне сердечника сам по себе, а его магнитный поток вращается внутри сердечника сам по проводник в окне сердечника сам по себе, а его магнитный поток вращается внутри сердечника сам по проводник в окне сердечника сам по себе, and в таком варианте который он показывает и о котором говорит магнитный поток в месте столкновения потоков, потоки выйует из сердечника пройдет через середину окна и вернутся в сердечник с обратной стороны и каждый в свою или через свою катушку завершит свой круг вокруг проводника породивший это кольцо магнитной линии . Романов любит пурги навести что бы не показать то, что происходит на сама деле. мне нравится его КАК БЫ. не как на сам деле, а КАК БЫ. да еще разделить это "как бы" на четыре части, потом померять длинну проводника в котором волновых взимодействий вообще не может быть исходя из длин волн на этой частоте и ими можно пренебречь и еще посчитать на каких частотах будет четверть волны. которая в этом тр. ни с боком ни с припеком. и данный принцип работы этого трансформатора основан не на взаимнотействии волновых процессов, а куна магнитных связях и с с умным связях и с с умным связях. не хочешь людям рассказать реальный принцип работы тр. в режиме преобразования энергии и врежиме СЕ, так хотя бы не заволи людей в заблужение. , это не поряточно.
Alex Kuzmin
на схемах принято начало обмоток обозначать точками. При таком соединении будет КЗ. Надо было соединить обмотки последовательно. Тогда,если обмотки одинаковые, на выходе будет ноль, если разные, то разность напряжений. В трехфазном трансформаторе перекос фаз не приводит к смещению нейтрали, просто появляется уравнительный ток в нулевом проводнике. Фаза напряжения во вторичной обмотке смещена на 180градусов относительно первичной. Насчет смещения фазы и асимметрии полуволн это Ваша фантазия(проверьте сами осциллографом). В трансформаторе передаваемая мощность определяется магнитным потоком и индукцией, и всегда справедливо утверждение, что сумма векторных произведений напряжений и токов в первичных обмотках равна сумме таких же произведений во вторичных. А то народ подключает вольтметр и амперметр, видишь, вот сила тока уменьшилась. А если подключить ваттметр то сразу все станет на свои места, поскольку он учитывает сдвиг фаз, который тоже изменится.Сколько раз давал себе слово не критиковать людей, не заглядывавших в учебник по ТОЭ, где расписана теория работы таких устройств и для неверущих все подкреплено формулами , откуда что берется.Потому что в ответ чаще всего слышишь типа сам дурак. Интернет такое позволяет.
And I have seen a lot of similar experiments by members.
https://www.youtube.com/watch?v=S_URR6Bk9cg
GFusion Core
https://www.youtube.com/watch?v=IdMVSiX2V7k
https://www.youtube.com/watch?v=vTCaF7R4Z-M
Spigel Branimir
https://www.youtube.com/watch?v=ARCLD3qgjmI
MrSiliks
https://www.youtube.com/watch?v=v0UXhKCWPuA
Igor Moroz
https://www.youtube.com/watch?v=fVj08I_A_KE
Ingener99
https://www.youtube.com/watch?v=YsGwdPqCpX0
Konstantin Lagutin
https://www.youtube.com/watch?v=ozGwb0glcXg
vasmus
https://www.youtube.com/watch?v=MzsvSHiRyvo
AC requires earth-ground.
I did not do it, one woman did it with two heavy swords. I told her keep your back straight and just swing them in front of you horizontally in opposite directions.
She and the chair were pulled forward.
I can't believe this simplest of ALL natural phenomena is still not recognized.
Good luck.
https://www.youtube.com/watch?v=4b69koOYry4
