Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 35 Guests are viewing this topic.
color
To say that you know the whole mechanism of how a generator works is the completion of an imaginary image.
Imagine imagining that a generator can work.
It doesn't matter if the generator can actually work.
Behind the imagining that the generator can work is the imagination imaged by one's sixth sense based on information obtained from various places in the meantime.
If you make a generator that is assembled from your imagination in this way into a reality, it rarely works.
Still, it does not discard the imaginary generator, but maintains the basic framework.
Because the effort to understand where the error occurred is in the generator of your imagination.
But your image generator is making no progress.
Almost all of them are caught by the kacher.
But the critical point at which the generator works is not the kacher.
The most important principle of operation is hidden where the output of the generator and the PSU are combined.
Начинаем с Теслы 2
https://www.youtube.com/watch?v=nSvT4L6BI74
24 minutes and 21 seconds.
Ruslan said: Turn on the little brain where there is a sine wave.
How long do we have to be deceived by this?
The reason for working the kacher on the grenade coil is that the thick copper lead connected to ground only responds to high voltage.
The coordination between the kacher and the grenade has already been completed from the moment the kacher is powered from the yoke-transformer. No further operation is required.
Emphasize again. With a variable resistor, adjusting the kacher's potentiometer is no longer necessary.
It is alternating current that makes the ground wire react at low voltage.
The kacher's static pressure is just a way to stimulate the ground wire a little more, and it does its job.
So the kacher is no adjustment needed, only the yoke-transformer push-pull rheostat potentiometer is adjusted.
I emphasize once again.
The kacher requires no adjustment and only needs to be adjusted with a push-pull potentiometer.
Almost all matter on Earth has free electrons.
Free electrons are electrons that are assumed to be free to move without interaction in the model for conductor materials. When metal atoms bond with metal to form a solid, valence electrons released from each atom can be approximated as free electrons.
In the classical Drude model, the valence electrons are completely separated from the atom to form a freely moving electron gas. This gas can be treated as an ideal gas. That is, the interaction between electrons and electrons is completely ignored. The electric field caused by the ionized atoms is assumed to be weak by the screen effect.
Karpanadze/Shark/Ruslan generators use these free electrons.
Free electrons react like electrons in a wire.
That's how the generator works.
The kacher's high voltage attracts or ejects not only electrons from the conductor but also many free electrons, especially in water, into the conductor at ground.
Because this is the role of alternating current whether the voltage is high or low.
That's why I say kacher don't mind.
Получение энергии из качера
https://www.youtube.com/watch?v=7Gs3LfzQYZw
This is the only one showing the frequency waveform at which a generator with a capacity of about 1 kW operates.
74.6636kHz
https://www.youtube.com/watch?v=JZ5v7iTfTo4
так ну в общем короче что здесь хотел сказать Вот сейчас просто накачки лампочка еле горит да то есть вот смотри на килограммы да видишь вот эти пики это есть то чего надо добиться Значит теперь подключаю Катчер но ещё происходит лишь о да то есть это вот эти выбросы но они и сразу же сразу же вот подключаю ещё раз да при тебе как только Получается эти выбросы знаю что происходит видишь Они моргают то есть они должны видеть что происходит Ну в принципе это тоже самое что О чём мы говорили да да Миш вот сейчас к Черни на своей чистоте и всё-равно привязывается да А вот и видно что Пика Нечистая после Пети идёт какая-то дрянь которая затормаживает поллер вот и можно видеть да видишь вот она выскакивает она внизу и вверху всё нормально то есть привязка идёт это из-за пропорции катушек вот сейчас Скачай мне на своей частоте поэтому нагрузку вот эту которую я тут предыдущем видео показывал подключить не могу но можно попробовать ещё да то есть говорю он вспышка лампочки видно да а довольно сильно А если подключить вольтметр кстати показывает сразу же напряжение что она подскакивает до 309 Вольт я тебе говорю катушка правильно намотана то есть всё происходит всё как надо либо сюда на никами долбанул либо чем Потому что это couture честно говоря з***** конкретно но посмотрит очень Вот такая вот белиберда получается
r2fpl
Free electrons without spin mean nothing.
It's just an attempt to match and answer where is the energy from? Generator like Kapanadze by Silva Paiva says that muons caught from the air are energy.
This is a really great story. Andre Fabien spoke similarly. Others see betetron, ignitron, magnetron and others here.
The most important thing to repeat in Kapanaga is why there is 24A on the ground wire!?!?
This is sine phase or pulsed DC because the clamp meter only detects AC / DC up to 400Hz!
Otherwise, it detects the voltage from the error. eg HV shows values but then the meter shows different values and jumps. Here it shows 24A constantly.
Is AC HV> 1000V current flowing in the ground? probably not. Why is the clamp meter showing 24A! You know the answer ?
However, from an eyewitness account, Kapanadze disconnected the ground wire for a few minutes and the device continued to operate by itself. This increases the difficulty of understanding.
color
r2fpl:
You ignore free electrons without spin contained in groundwater=water. ;D
Water is said to be made up of oxygen and hydrogen.
The quantum leap electron performance of hydrogen is called probability.
Just as you are a crow about the working principle of a Ruslan generator, your words are as much a crow as the quantum leap electrons of hydrogen stimulated by a kacher high voltage. ::)
You're familiar with plating metal in water using conventional battery power and breaking down rust in metal, but you're like a crow about the fact that free electrons without spin move into the metal. ;D ;D
Experiment Copper , Aluminum , Brass , Nickel plating at home
https://www.youtube.com/watch?v=d86g0svbIG8
battery metal rust removal
https://www.youtube.com/watch?v=54ADeB6V1rQ
And,
Please post where this comes from. ;D
I have a hobby of imagining things I haven't seen, but this requires proof.
There seems to be a need for an attitude trying to figure out what causes gravity, what causes magnets to attract each other, and when electrons are converted to light.
Before that, you should first know how the much easier Ruslan generator works. ;D ;D
One of the many things Ruslan didn't mention is the grenade output and the PSU input... ;D ;D ;D ;D
How to break a coffee pot
https://www.youtube.com/watch?v=0TOVIMn-ubs
r2fpl
Quote from: color on June 23, 2021, 06:03:22 AM
Plasma is formed because the resistance has dropped to zero after the heater has heated up. You can see it more clearly here.
I don't know what gravity is and neither do you, because no one knows. Seeking explanations for these matters is pointless. People don't know how to build a device, but they know how to use it, so searching for an explanation can be postponed.
I don't know if Ruslan / Akula is the same as Kapanadze. Probably not.
It was once said that Kapanadze was doing electrolysis and found a way to FE. Is it true ? is this the moment I don't know, but there's a movie on YT.
How do I know that Kapanadze has disconnected the ground? After all, there is a whole thread on the forum about it. You haven't read.
r2fpl
Ruslan is a liar and has proved it many times. Maybe he was doing it on purpose so as not to repeat his devices but why did jo show him so many times before.
ok. it doesn't matter now.
