Speed up Under Load Garbage Explained.
Started by tinman, March 18, 2019, 11:09:37 AM
tinman
Quote from: Void on March 18, 2019, 12:13:10 PM
Here is an overview of where Thane Heins is at as of about 7 months ago:
CONCLUSION Electric Vehicle Regenerative Acceleration Technology Introduction
https://www.youtube.com/watch?v=M1I09omDBEo
I am not really so knowledgeable about electric motors and generators, but Thane Heins seems
to be saying that when his electric bike is going over 30 km/hr that his regnerative coils
can charge the bike's battery without causing any extra loading on the bike's motor. Below 30 km/hr
he says his regenerative coils (or whatever he calls them) when charging the battery cause an
increased loading on his motor. He also says it is not perpetual motion however, so he seems to
be saying that it is not COP > 1, even though at speeds over 30 km/hr he says his generator coils
charge the battery without increasing load on the motor. Whether he has done the proper measurements
to really confirm that, I couldn't say.
This video is the one to watch Void.
When you watch it,you will see he has exactly what i said going on.
If it was true that he had this regenerative acceleration ,then he would not need the electric motor of the bike still going to spin the wheel.
https://www.youtube.com/watch?v=4znhQL8rI6M
Brad
tinman
Quote from: SeaMonkey on March 19, 2019, 08:00:48 AM
Bistander is striving valiantly to attain clarification on
what Turion means by "speedup under load" and precisely
how and when it occurs.  The discussion tends to go
round in circles because of Turion's inability to explain what
he means with precision and with correct terminology.  Sadly,
most of Turions's postings are emotionally laden lamentings
and accusations against any who question his incoherent
ramblings or any  who seek to obtain explanations in correct
technical language of what it is precisely that he is attempting
to say.
Erron's position is quite clear.  If Turion is proven wrong in any
way it will detract immensely from what he has invested in the
whole proposition.  There won't be any "secrets" to be revealed
or any books to write.
Recently Turion has admitted that while his generator speeds up
under increased loading that the power delivered to the load
or loads decreases.
The question remains:  Is there really anything to see there or is
it another case of mistaken results?  And the secondary question:
Why is Turion so reluctant to offer visual evidence of his claimed
generator's operation which would demonstrate to some extent
that he is speaking truth?
Great thread TinMan!
Bistander is just banging his head against the wall over there,and i simply do not understand why he stays. Aaron the rookie treats everyone that don't agree with him like they are second class people.
I have never seen such an uneducated person(Aaron) be in charge of a forum that requires some one with great knowledge and understanding.
Bistander would run rings around that rookie Aaron,and as far as Turion go's--well the Matt and Dave team,they have no idea as to what there own machine is trying to show them.
Turion will not come here,as he cannot/will not do the test i require in the first post of this thread.
He will not do it because he already knows the outcome will show exactly what i say it will show,and he will never show the 400 watts in==1800 watts out generator-->never.
He stays at Energetic forum because the rookie likes these bullshit overunity machines--he makes money off them writing books full of secrets.
The rookie claims that the faraday disc generator(the homopolar generator) has no backtorque when a load is placed across it's output,which is absolute garbage. It wouldn't work as a motor if it did not produce backtorque when loaded.
I will also be opening a thread on the homopolar generator/motor once i have finished mine.
So this is how we flush out the fraudsters.
I wonder if the rookie will be putting his own name in his forum thread-- overunity frauds ?.
Brad.
Void
Hi Tinman. Thane Heins seems to have come to the realization that it is not COP > 1.
He does seem to be stating that he thinks his setup will extend the range of an electric bike
before it requires recharging (improve efficiency), since he claims he can charge the battery above
30 km/hr without adding extra loading to the motor. It seems to me that should be an easy thing to put to a practical test.
Just test the range of the electric bike on a specific highway route without that 'regenerative charging', and then test
again using the 'regenerative charging' when going above 30 km/hr, under the same approx wind conditions, and see if
the range of the electric bike is really increased by much or not. Repeat that test a few times to make sure
of the results, and he will have a straight forward answer. Either it really extends the operating range of his e-bike in
some sort of significant way, or it doesn't. :)
shylo
Hi Tinman you said,
When a load is placed on the generators coils,a magnetic field is built around the cores and coils of the generator. This shields the coils cores from the induced eddy currents from the passing PMs on the generators rotor.
So this means that the generating coil/core make a pole that is opposite of the magnet is approachingand then switches to the same pole when leaving?
Thanks artv
tinman
Quote from: shylo on March 19, 2019, 08:59:43 AM
Hi Tinman you said,
So this means that the generating coil/core make a pole that is opposite of the magnet is approaching and then switches to the same pole when leaving?
Thanks artv
Normally yes,but that can change,and depends on the magnetic relaxation speed of the core material,and the speed at which the PM fields are passing the coil.
I will be showing this in up and coming video's.
Brad
