Radiant power from Solid state Tesla hairpin circuit
Started by evostars, April 19, 2019, 09:55:08 AM
Kator01
well,
the voltage certainly depends on the relay-winding-ratio. I could not find any detailed specification for the resistance of solenoid of YH185B-Relais
They vary starting with 90 Ohm to 1100 Ohm.Maybe some member here can help with this information ?
By the way very useful analysis of the hairpin-circuit presented by Fred B
Part 1
https://www.youtube.com/watch?v=wU8LYiLLpGs
Part 2
https://www.youtube.com/watch?v=N7gPeIVVy0A
Mike
gyulasun
Hi Kator01,
Here is a data sheet for the YH185 relay series from its manufacturer:
http://www.yhrelays.com/e/upload/s6/fck/file/2013-05/YH185.pdf
The YH185B relay type has a 90 Ohm coil resistance, for operating voltage at 12 V.
Gyula
Grumage
Quote from: gyulasun on May 17, 2019, 06:12:11 AM
Hi Kator01,
Gyula
Hi Gyula.
As an additional note most of the automotive relays seem to have a resistor placed in parallel with the operating coil.
This is based upon my observations, having taken quite a few apart over the years.  :)
Cheers Graham.
gyulasun
Hi Graham,
Thanks for the additional information and yes (a resistor or a diode or a diode with resistor or none of them) may be found paralelled with the relay coil and this is mentioned in the data sheet at the ordering code explanation,  see attachment.
Cheers
Gyula
Kator01
Hey Gyula,
thank you very much.
@grumage, thanks, did not know this.Maybe they put in the resistor to avoid excessive sparking which is what we actually want for this application
Mike
