1000000 Kilometer with 1 KWh-battery
Started by lancaIV, May 13, 2019, 06:33:00 AM
calculation : average 1 KWh electric per 100 Km range consume
available 2021 : Yinlong Lithium Titanate Oxide Battery ,300 US$/KWh capacity, 25 000 100% DoD charge cycles ,15,6 Kg/KWh weight
https://www.google.com/search?q=yinlong+lto&rlz=1C1AVFC_enPT930PT930&oq=yinlong+lto&aqs=chrome..69i57j0l4j0i22i30l5.6184j0j7&sourceid=chrome&ie=UTF-8
25 000 KWh available by 25 000 charge cycles / 1 KWh = 25 000 x 100 Km = 2 500 000 Km capacity by 15,6 Kg battery ,300 US$ priced
300 US$/ 2 500 000 Km = 0,012 US$cent/Km battery costs ,
                                  soon 0,01   US$cent/Km
                               or         1   US$cent/100 Km ( only storage excluded the electricity)
with https://overunity.com/13955/oldie-but-goldie/msg559183/#new Saburo range extender :
                                       10 000 000 Km per 1 KWh capacity,25 000 cc, battery
                                       by this claim
                                       https://advances.sciencemag.org/content/3/12/eaao7233
                                      100 000 000 Km  per 1 KWh capacity,250 000 cc,battery
                                      https://twitter.com/fermatslibrary/status/13123821560653
                     Kilo- = 1000 metres. /Mega- 1000 000 meters./Giga- 1 000 000 000 meters  range "Batterie-Set"
                    100 000 000 Km =                                                100 000 000 000 metres
        Tera-Metres-Battery-Factory
        theoretically "permanent drive",permanent battery re-charge cycle
                                        f.e. as autonomous intercontinental drone
                              https://translate.google.com/translate?sl=de&tl=en&u=https://geschaeftsbericht.post.ch/15/ar/de/jahresbericht/geschaeftsentwicklung/logistikmarkt/drohnen_fuer_die_paketzustellung.htm
                     civil,military,guerilla,legal and criminal use we can expect ,ABC-weapon/drugs/migrants
https://geospatial.blogs.com/.a/6a00d83476d35153ef022ad3c0d118200b-popup
means by 8766 KWh delivery per year by 1 KWh/100 Km consume = 876 600 Km autonomous drive per year
( but cause this 1 KWh/100 Km is based by average 40 Km*h velocity = 8766 h x 40 Km = 350 640 Km per year maximal drive range !
  the planetary year time is fixed with 8766 hours,modification physical not possible ::)
Compared  - in average - the US car mileage : https://www.caranddriver.com/research/a32880477/average-mileage-per-year/
                                    13,500 miles every year  or 21,726 Km every year  =  60 Km per day         )
not bad for a claimed 40 US$/KWh production costs "nuclear battery" device and 10 years+ long-life
how much per KW output - only the thermionic converter costs- this inventor calculates ?
https://judbarovski.livejournal.com/
Invented heterodyne antenna thermo electric generator is very cheap and small and light and without any moving parts. Its energy efficiency is near 100%. Carnot limit is not relevant.
For example, a hybrid electric vehicle can use four times less fuels vs. ICE, so generating four times less exhausts,
and I have developed a technology for very mass and cheap extraction CO2 from the air.
classical car drive ,modified :
https://de.wikipedia.org/wiki/Panhard_Dyna_Z Up to 50 hp gasoline ic-engine motorized,up to 144 Km/h maximal velocity/speed
        by 815 Kg car weight
this is  https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001020&CC=FR&NR=2792258A1&KC=A1 e-drive level
Un moteur électrique de I ch à 6000 tours minute,soit I00 tours seconde,démultiplié par un rapport de I/50,possède une force de couple instantané,à 2 tours seconde à l'arbre, égale à la plage de couple instantané différentiel ou ponc-tuel d'un moteur de 50 ch.
        50 ch    = 50 chevals/horses = 50 hp
average consume 1 000 Watts ,let us assume by average 40 Km*h street legal speed/velocity (urban zone)
means 2,5 KWh/100 Km average consume by conventional 4x 500 Watt rated electric motors
means 1,0 KWh/100 Km average consume by modified      4x 500  Watt rated electric motors
without Saburo range extender
with Saburo,by claimed C.O.P. 5x performance,
means 0,2 KWh/100 Km average consume by modified     4x 500 Watt rated electric motor ( magnetic diode, double winding)
                                                The charge time need for an 1 KWh battery ?
https://www.nextbigfuture.com/2017/12/super-aluminum-graphene-battery-has-a-5-second-charging-time.html
        :o  so long to wait ? 8)
                                 for US average daily 60 Km range and up to 100 000 000 Km charge range
                                            100 000 000 Km/ 60 Km = 1 666 666 days = 4563 years
But let us begin with the           Lithium Titanate Oxid        (Yinlong or Xalt or ... ) 25 000 + charge cycles /Saburo battery-set :
                           456,3 years free drive are not so bad,is it not ?
           Beyond   Lithium           Natrium Titanate Oxid
And " Thanks God or A.I . ", the consumer will not have an alternative in our autonomous drive = human driver free future !
                                                             human driver exodus !
fact :               from scientifical view the actual e-cars are 90-99% with battery capacity overestimated/overpowered !
                      x https://translate.google.com/translate?sl=de&tl=en&u=https://www.handelsblatt.com/mobilitaet/elektromobilitaet/carsharing-desaster-warum-reines-e-carsharing-ohne-subventionen-chancenlos-ist/27392300.html
But statistically speaking, cars stand idle for a good 23 hours a day in the area.
Seen in this way, there are more than 48 million "parking spaces" in  Germany .
                     100 % "totes Fuhrpark Kapital"
                     x 1h/24 h use
                     = 5% ,95% Abbaupotential
                     x 10% down to real need  10% down to 1% from actual KWh battery pack
                     = 99 % less production or less costs
                      1 e-car battery capacity actually = 10 -100 e-cars capacity in future
                      90-99% less material (ab-)use per electric drive car
                     lithium/natrium/aluminium/graphene and other battery materials in use production capacity enough
https://de.wikipedia.org/wiki/Panhard_Dyna_Z#/media/Datei:PanhardDynacabriolet.jpg this looks really similar Citroen DS 21/23
        https://de.wikipedia.org/wiki/Citro%C3%ABn_DS
                           with Lithium Titanate Oxid battery + Saburo each e-car transforms to an e-power plant
                                             less than 1 US$cent/KWh 24/365 electricity generation
https://translate.google.com/translate?sl=de&tl=en&u=https://www.hybrid-autos.info/elektro-fahrzeuge/loremo/loremo-ev-2008.html
6 KWh consume conventional e-drive               per 100 Km (included brake energy recuperation ?),2008 standart
3 KWh consume modified      e-drive                per 100 Km,2021 standart
0,6 KWh modified e-drive + Saburo C.O.P. 5x   per 100 Km,2021 standart
without "hype" the pure electric car selling worth between 5000 Euros (E.U. Renault-Dacia level) and 2500 Euros (Renault Kwid India level)
             based by their final market price/Kg weight  and Loremo 450/470 Kg Kg car weight
        http://elweb.info/dokuwiki/doku.php?id=loremo
less https://translate.google.com/translate?sl=de&tl=en&u=https://www.adac.de/rund-ums-fahrzeug/elektromobilitaet/kaufen/foerderung-elektroautos/
                  a 24/365 4-wheeled LOREMO electric power plant with "electric car"-function for net 4000 Euros in Europe
                 a 500-1000 (KW output dependent) Euros 24/365 "Zero (grid) Energy building" electric source
Attention : related KILOWATTLABS charge cycles number "1.000.000 charge cycles" claim
https://www.eevblog.com/forum/renewable-energy/supercapacitor-energy-storage-and-energy-server-from-kilowatt-labs/50/
https://www.solarquotes.com.au/blog/arvio-supercapacitor-battery-review/
the Kilowattlabs Sirius "Supercapacitor" to see as like it is : Lithium Titanata Oxide battery (array) !
So not ,like to read here , https://www.solarquotes.com.au/blog/wp-content/uploads/2018/05/supcaptechspec.gif
1.000.000 (1 Mio.) charge cycles but ,
like here calculated : https://www.cleanenergyreviews.info/blog/home-solar-battery-cost-guide  : 10.000 charge cycles ! By 100% DoD !
Sincere
OCWL
https://overunity.com/18385/e-drive-platform/ Paul-R reply #12
Excuse-moi,I am sometimes chaotic,information-overflowed !  ::) :P
From 1896 Kriegér Eletrolette https://en.wikipedia.org/wiki/Kri%C3%A9ger_Company_of_Electric_Vehicles (with later known KERS included )
to the modern Citi-Mobilette
step-by-step :
                                                speed limit 25 Km/h max
                                                and " power(peak) in hpp or KWp -to-weight in Kg"- ratio observation
1.                                             http://www.duke-ev.org/prototype-evolution
2.                                             https://en.wikipedia.org/wiki/Sinclair_C5
3.                                             https://en.wikipedia.org/wiki/Mercedes-Benz_F-Cell_Roadster
                                               speed max. limit 40-45  km/h
1.                                            http://www.evalbum.com/314 Lavenami
2.                                            https://www.citroen.pt/ami    https://www.opel.de/fahrzeuge/rocks-e/uebersicht.html
3.                                            https://www.youtube.com/watch?v=Hf31fQJVWOU
                                               Citycar speed max. limit over 50 Km/h
1.                                            https://www.prismz.com/automite/ to electric KW conversion
2.                                            the most sold US-market e-"car" before Tesla Motors Inc. entry :   https://en.wikipedia.org/wiki/Citicar
                                    this as fundament for the modern Nearly-/Net Zero-Energy car/etrike/quadricycle
        100 Kg weight mobiles like
        https://hopper-mobility.com/
                                      https://www.canyon.com/de-de/e-bikes/future-mobility-concept.html
Making part in the development progress :                  https://en.wikipedia.org/wiki/FreedomCAR_and_Vehicle_Technologies
                                      cheap electric drive (5 US$ KW,15 US$/Kg)and cheap inverter (< 12 US$/KW) , based by 55 KW drive
1981 : Mercedes-Benz https://www.planetcarsz.com/carros/1981-mercedes-benz-nafa-concept
                                       https://emercedesbenz.com/tag/short-distance-nafa/
                                        and Nicolas Hayek, https://en.wikipedia.org/wiki/Nicolas_Hayek
                                        at first in partnership-search with VW and FIAT,            SMART car-concept                ------------------------------------------------------------------------------------------------------------
100 Kg "egg-mobility"  http://electricandhybridcars.com/index.php/pages/PaulArzenselectricegg.html                           with,actually 340 Wh/Kg ,prospected 1000 Wh/Kg LTO-battery
        https://innolith.com/de/
        possible
        the mobile its body material :
          https://theconversation.com/transparent-wood-is-coming-and-it-could-make-an-energy-efficient-alternative-to-glass-154981
        and
             https://www.scientificamerican.com/article/stronger-than-steel-able-to-stop-a-speeding-bullet-mdash-it-rsquo-s-super-wood/
https://www-spiegel-de.translate.goog/auto/fahrkultur/toyota-ex-ii-von-1969-das-e-ei-a-28c11442-9f7a-481d-9111-63a999c3c530?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de#fotostrecke-01bbaa69-3769-41fc-b227-32db7957e514
Which travel kind is faster,an overview :
https://www-zukunft--mobilitaet-net.translate.goog/167997/analyse/tuer-zu-tuer-reisezeit-stadtverkehr-pkw-miv-oepnv-radverkehr-pedelec-gleichheit-subjektive-verzerrung/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de
                        for short distances a 25 Km/h fast mobile  ,bike-trike-quad-drone ,is unbeatable !
Projekt Negawatt-AUTO (NegaWatt by Amory Lovins,Hypercar https://rmi.org/insight/hypercars-faq/ )
e-drive rated/nominal :   1,5 KW 12 Volt
curb weight 99 Kg
power to weight ratio : assumption 1,5 KW /0,745 = 2 hpp/99 Kg = 0,02
Top speed :     25 MPH (40 KPH)
compared
Citroen Ami
e-drive rated/nominal : 6 KW/8 hp  48 Volt
curb weight : 485 Kg
power to weight ratio 16.5 Hp/tonne  or 8 hp/485 Kg = 0,0165
Top speed : 45 Kph (limited , L7e quadricycle rules )
Now : https://overunity.com/18385/e-drive-platform/  #9
Interestant the QS AC  motor delivered data    https://www.qsmotor.com/       :
48 V 24 Km-h,    60 V   30 Km-h and   72 V     36 Km-h average velocity
what would mean - linear calculated -
                                                             220 V         110 Km-h
Lavenami 1,5 KW DC 12 Volt   to  1,5 KW AC 220 Volt modification
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=10011074&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
In the mosaic/image the e-drive technical numbers :
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=DE&NR=10011074A1&KC=A1&FT=D&ND=3&date=20001207&DB=EPODOC&locale=en_EP#
The energy delivery source for the Lavenami conventional DC output battery to DC/AC inverter to AC motor ( inrush current calculation and inverter power configuration attention  !)
This is at first "race track"-concept,not for street legal use,https://en.wikipedia.org/wiki/Sinclair_C5
Enthusiasts have established owners' clubs and some have modified their vehicles substantially, adding bigger wheels, jet engines, and high-powered electric motors to propel their C5s at speeds of up to 150 miles per hour (240 km/h).
The R&D for the right weight (Elk-teste)/speed max. and consume per hour/ per 100 Km search and measurement ratio !
After Lavenami,the next "100 Kg weight Cititrike"  tuning project :
The technical numbers  https://hopper-mobility.com/ , claimed :
2 KWh/ 100 Km consume and 25 Km/h speed = 500 Wh consume per hour
finally : the tuning of https://www.canyon.com/de-de/e-bikes/future-mobility-concept.html  to NetZero-Energy Cityquad
                                         autonomous,external energy- and driver-free , Citymover
                      100 Kg Citymover for later commercial maximal 2500 Euros fob factory  individual endconsumer price
                                                              quad-fleet-share,timely
                  When a Citroen Ami with 8000 Euros costs leases for 20 Euros per month
                                                       a 2500 Euros alternative leases for less !
When we look for VW Kaefer/Beetle - Fiat 500 - Citroen 2CV  ic-engine numbers,the cars density per household ,the catalyser process energetic losts,the industrial claimed/practical experienced car consume per 100 Km ,we have to observe that in the last 50 years,
                      by less urban average traffic velocity
the traffic units consume increased by over 200 %,independent fron Rio-Kyoto-Paris climate conference
                       thermical engine consume between 60´/70`cars
                       cars with 6 lt. fuel consume/100 Km and   7:1 compression ratio
                       related "modern turbulent times" intelligence
                       cars with 6 lt. fuel consume/100 Km and 14:1 compression ratio
                      a near 100% "fuel + air"  mix consume per 100 Km increase !
                      the sub-/urban metropoles "heat bell", 100% higher exhaust emission by 350 ° Celsius !
                     + in the last decades over 150% room heating energy consume per capita increase
                     ( sqm living area/capita 60´/70´ versus sqm/capita 2021 X in-door average temperature 60´/70´ and temperature 2021 )
                     Fujitsu : between from 0°C to 15° C heating = 100 heat units and 0°C to 20°C = 200 heat units is an one hundert percentage energetic increase,
        5°Kelvin more = 100% more
                    this statement https://www.fenixgroup.cz/de in their home project confirmed
                    energy/health/comfort/costs
                    Post-WW2 generation living comfort and "NewAge"-comfort behaviour
                    12-14° C in winter                                     18-21° C in winter
                    https://lookaftermybills.com/blog/average-room-temperature/                    https://www.bbc.com/news/magazine-12606943
                    consense : maximum space temperature 18° C,included dehumidification,
  • 24°C+ – Cardiovascular risk of strokes and heart attacks
  • 21-24°C – Increasing discomfort
  • 18-21°C – Comfortable temperatures
  • 16-18°C – Discomfort, small health risks
  • 12-16°C – Risk of respiratory diseases
  • 9-12°C – Risk of strokes, heart attacks
  • <9°C – Risk of hypothermia
by law : 18-21 °C ( in German Federation ,estates dependent)
https://www-mieterbund-de.translate.goog/index.php?id=442&_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de
                    and personal body heating ( in summer cooling )                    https://embrlabs.com/   https://spectrum.ieee.org/wristify-thermoelectric-bracelet-would-reduce-energy-consumption
                    http://www.rexresearch.com/cuinanoagwire/cuinanoag.html
                Super-insulated clothing could eliminate need for indoor heating  ( 12 Watt per hour consume)
also as 4-seasons open-sky/cabriolet like https://en.wikipedia.org/wiki/Mercedes-Benz_F-Cell_Roadster electric wear
to see here : Daimler Benz reasearch paper/application (80 W per hour consume )
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=12&ND=3&adjacent=true&locale=en_EP&FT=D&date=19910620&CC=DE&NR=4038167A1&KC=A1#
                    btw :
                    https://www.hellenicshippingnews.com/bank-of-america-predicts-crude-oil-will-skyrocket-43-to-120-a-barrel-by-next-summer/
1972 : the Clube of Rome REPORT
https://www-spiegel-de.translate.goog/wissenschaft/mensch/klimawandel-der-oelkonzern-total-wusste-seit-1971-von-der-globalen-erwaermung-a-b31a50ef-1d28-4774-a0a3-ca70756c0b70?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de
